20" universal 5 lugs. Will they fit the bolt pattern 5x120?
Hello people. I found a nice set of 20" halo rims that are 5 lug universal. Will they fit my 2012 TL? Are Acura runs hub or lug supported?
The Original Shawdy
5 lug universal may fit as long as it supports 5x120. For our vehicles you mount the wheel on the hub with the studs poking out and tighten them down with lugs.
Not like Volkswagen's where the lugs thread threw the wheel to the hub.
The Original Shawdy
They need to clear caliper and center hub. If the center bore is bigger then the oem hub. You can install hub centric rings to solve that. 19" can rub but depends on wheel specs and if you're lowered or not. The oem 19's don't run at all.
