Notices
09 TL struts?
Old 03-03-2019, 03:39 PM
Registered Member
09 TL struts?
Are these factory struts only bad when they leak oil or do they wear out without showing oil on the strut assembly?
oreo615 is offline
Old 03-04-2019, 12:49 AM
Registered Member
my shocks are worn out and they don't leak. I have 100k miles on my car. I lowered mine on H&R springs about 40k miles ago...
if your car bounces over bumps or feels like it rocks back/forth or see/saws at all.. they are worn out.
23109VC is offline
Old 03-04-2019, 11:21 AM
Registered Member
losiglow's Avatar
They can wear out without leaking oil but you may not notice, since unless they're defective, the change will be subtle over a long period of time. Until you change them, you won't really notice. But once you replace them, you'll likely notice a big difference. I changed mine at about 120K and it brought the car back to life. I also did the sway bar end links, upper control arms, lower ball joints and tie rod ends eventually. But even with only the coil replacements, the difference was substantial. Doing all that other stuff basically made it feel like it did when it was new.
For sure. It should be very solid on bumps. Almost too much so. And body roll should be relatively minimum. I've literally drifted on several occasions and it handles as well as my 3G did with BC coils set on firm. And I'm only FWD.
losiglow is offline
Old 03-10-2019, 09:57 PM
Registered Member
What did all those other Suspension fixes cost?
23109VC is offline
Old 03-14-2019, 06:39 AM
Registered Member
Anyone find good quality Quick struts for 09 TL rear?
Looking for a pair of good rear strut assemblies
oreo615 is offline
Old 03-14-2019, 07:02 AM
Received 14,176 Likes on 10,524 Posts
well, OEM comes to mind...
any "after-market" OEM style shock will be just that...an imitation of OEM.
so your choice... You can use OEM's from the dealer or you can head to www.rockauto.com to pick up an OEM style aftermarket like monroe.
I would pick OEM from the dealer, but then again, I am not you.
www.acuraoemparts.com
www.oemacuraparts.com
these two dealers are great to deal with!
justnspace is offline
Old 03-14-2019, 09:47 AM
Registered Member
losiglow's Avatar
Parts are generally cheap. It's the install that's more expensive. I tackled it myself. Upper control arms (with new bushings) run about $35 each. Sway bar links are about $15 each. Ball joints - $15 each, tie rod end links - $20. Coils were about $160 each.
losiglow is offline
Old 04-23-2019, 02:13 PM
Registered Member
I changed the front struts and started on the rear but ran into trouble getting the old one out, so I put it back together to wait till I have time. Might change the front end links because I have a slight "clunking" over bummy roads.
oreo615 is offline
Old 04-23-2019, 06:19 PM
csmeance's Avatar
Received 1,070 Likes on 750 Posts
I just put in some KONI FSD's and they rock! The rears were visibly leaking on my 13 TL
csmeance is offline
Old 04-26-2019, 12:09 PM
Registered Member
My 09 - Left front leaked and eventually started clunking over rough roads so I replaced both fronts with Acura one piece strut assembly.
Contsi is offline
Old 05-29-2019, 08:52 AM
Registered Member
how much did those set you back?
Botlfed98 is offline
dark inspire
21
03-14-2005 04:03 PM
ACURA-C
04-04-2003 04:37 PM
Red Rider
02-16-2003 11:52 PM
JRock
04-22-2002 11:18 PM
SilverKnight
Second Generation CL Discussion (2000-2003)
03-07-2002 08:34 PM
Quick Reply: 09 TL struts?
