2010 Sh-Awd interior lights stuck on and flash
Driving home my interior lights randomly turned on.
Lights will not turn off unless I select /off/ for the lights. Lights will not turn off in door mode.
Car does not indicate a door is open.
All doors tested and all switches seem to work fine..(car beeps when door is closed and keys are out car) .
Also, the interior lights flash with the right turn signal (only).
Rear view camera is also stuck on now.
Any ideas? Car is stock.
Had no codes but solved the problem.
Moisture build up on the driver side fuse box / ecu.
It had been raining heavy all week. Gonna check and see if maybe the drains for the sunroof are clogging.
Literally all I did was run the heater full blast for a little over an hour with the car closed. Then parked it overnight in a friend's climate controlled garage with the windows down. Been perfect since. And it's still raining daily.
UA6/7
04-24-2020 07:44 PM
scott06512
1G RDX Problems & Fixes
02-11-2009 11:30 AM
