trans
Old Jun 30, 2025 | 01:43 PM
dani363628's Avatar
trans
Hi, i have a 2012 tl 3.5, with 110k, starting to shift a little rough. Not sure if trans has ever been serviced. Should I go ahead and do a trans flush with the acura atf dw1?
Old Jun 30, 2025 | 03:55 PM
trans drain and refill yes.
Old Jul 3, 2025 | 02:49 PM
csmeance's Avatar
Do yourself a favor and buy a case of DW1 ATF from a honda dealer, I got mine from Bernardi acura around $7/quart plus shipping: Look into the 3x3 method to change the trans fluid, you'll end up using about 3.5L of fluid each time depending on how long you let it drain for.
https://acura.bernardiparts.com/Acur...RANSFLUID.aspx
Old Jul 6, 2025 | 11:00 PM
dani363628's Avatar
That’s exactly what i ordered will look into the 3x3 method thanks
Old Jul 7, 2025 | 09:06 AM
Flyinblyian's Avatar
Can't hurt to replace the inline ATF filter as well, located under the battery tray. I suggest buying OEM from actual dealer and not Amazon, eBay, etc.
Good luck!
tatertot3381
Nov 1, 2015 04:09 PM
yahelou
Jan 19, 2014 09:26 AM
2.5TLdude
1G TL (1996-1998)
Apr 7, 2004 05:26 PM
