Torn weather stripping
Anyone else have an issue with the weatherstripping on the molding tearing and continuously peeling back from front to rear? I'm referring to the 1/8" rubber strip that is attached to the chrome molding piece that runs from the base of the windshield to the rear window. I have to keep trimming it as it peels back because it flaps all over causing a buzzing noise and staining the paint. Based on the parts image, it appears these molding pieces simply snap in place? If so, it seems like they should be pretty easy to replace. They're $86 each though, which sucks.
My 2010 TL is doing the same thing. I ordered them plus the Windshield molding (which shrank from the sun causing a passenger side water leak) from Acura this morning.
I have had the same issue with the rubber seal/molding on top of the chrome being completely worn out. I took my TL to an Acura Dealership and was quoted $1200 just to replace all 4.
1200? That's Ridiculous. I'm gonna Check out Youtube to see if anyone has done it already. Dealerships pricing can be outrageous while Some dealerships can be quite reasonable.
I am having the same issue with my 12. I keep it parked in the garage at home and in the parking garage at work so the car sees very little sunlight. I have gradually taken off the seals cause they keep peeling off with the wind and flapping all over the car around them making a lot of noise when I drive it.
https://acurazine.com/forums/4g-tl-p...e-trim-902939/
^^^^ My bad. The OP was actually referring to the shiny molding at the base of the side windows, which has a thin rubber strip attached. Definitely not that chrome strip on the roof.
Mine has completely disintegrated. I was finding pieces on my driveway and finally realized what it was. Car is 2012 so am disappointed that these fell apart. $1200 to replace they must be mad.
You were quoted $1,200!? This is a DIY job. I got the left and right side trim from the dealer ($90 per side) and installed them myself. Super easy.
Mine got replaced via insurance. My car was caught in the cross fire of a fight in a parking lot. Glass was thrown, people fighting ON my car...so I filed a clam to fix the damage. all parties agreed that the scrapes and scratches that were on the chrome pieces were most likely caused by the event. By replacing the chrome piece the rubber is also replaced. Just saying... it was unfortunate and fortunate at the same time.
So the dealer wanted $120 per side. Auto parts store doesn't have stripping thing enough to just replace etc.. So I ended up taping the chrome with painters tape and using Black Silicone Adhesive Sealant $8 bucks. Simply cut a small hole in the nozzle lined it up in the groove and just filled the slot in. My car is black so it came out good. Not noticeable unless you are searching for it.
Related issue: the rubber on the door trim pieces is also now peeling. I may go ahead and order all four even though my passenger side is the only one peeling away at this time. $72 each 🤦♂️
9000revs
1G RL (1996-2004)
02-05-2012 06:14 AM
