Speakers blown and rattle
#121
I had the same problem with my 09 TL which I bought a month ago. The left front door speakers was blown. It rattles on a certain frequency. If you listen to soft music it is fine but ones you listen to a music with big bass you can hear a rattling noise. I brought it at the dealer and they replaced it no charge. My question is, how do you remove the speakers from the side door panels? Do you have to remove the door panel or the speaker grill just snaps out? Any pics on the web or post here on how to replace the speakers from the door panel? I would like to replace it with the Infinity Kappa if it blows again.
#122
Back From The dead
In both cases mine started out that way but got progressively worse. I had to get them replaced.
#123
#124
2015 TLX SH-AWD Elite BWP
I would say that my wife Premium Santa fe has a better speakers at least and after a year , no issues and no rattles form speakers at any volume level.
I'm disappointed form this point of vue with my TL. I hope it will be fixed.
#125
Hey Guys, I've had my 2010 TL SH-AWD (Non-Tech pkg) for about 3 weeks now. Does anybody else seem to feel that there is plenty of Highs & Lows, but can barely hear the mid-range? It's almost like the door speakers aren't working. And also, i feel that i have to have the volume over level 20 on radio stations to hear anything, cd's around 12-13, anything after 15 and it's distorted.
My biggest concern is the mid-range speaker. not sure if their blown, or just not getting enough power from the amp? Non-Tech guys, i could use your input. I'm also going to the dealership today, to sit in a new TL Non-Tech to compare the system to see if it sounds like mine. A little disapointed, the Bose 8 speaker system in my Altima SE-R and Altima Coupe sounds alot nicer than this
#126
An obvious point, but did you check your sound settings? Don't know about non-Techs but in Techs you can adjust the center channel speaker. Maybe yours is turned way down? Also, if the non-Tech's have the Dolby surround feature, you might play with that. I've found it sounds better in the off position with radio and XM, but better in the on position when using HDD, IPod and most disc sources.
#127
#128
My TL is 2 weeks old !
#129
My 10 months TL starts to do same thing on the front right door speaker. I have to go to my first oil change soon and I'll ask the dealer to change it. I'll check if the left is doing also , as the right one is so obvious .
#130
I was in for an oil change and the buzzing right front speaker - It one of the 1st hot days in May - and the speaker wouldn't misbehave. Except after I had left and the car cooled and now it does it every morning
#131
You have to change it. I'm wondering if the new speaker will have same problem after a while...
#132
Mine did the same thing but the trick for me was to change the station to an all talk station and turn it up. It would crackle and pop every time on a talk radio.
#133
Blown front right door speaker. I'll have it changed on next service...that should put me into a loaner. But after the warranty expires, I assume I'll need aftermarket speakers.
#134
my speaker noise finally pushed me to get it fixed - Only it wouldn't do it at the dealer. Car had to be cool for the speaker to make noise (as in my morning drive to work, or long drive w/ a/c on). So I left work ran & the a/c at the lowest temp. Speaker still wouldn't make any noise (thought a wasted trip) but then when it was time to exit the tollway for the dealer - Finally it started the noise it makes - dealer had the speaker in stock - replaced in about an hour while I waited
#138
Having the front driver side and passenger side door speakers replaced on Tuesday. I can't believe that there are this many problems with the speakers without Acura actually offering better replacement speakers. The system sounds great when the spearkers are functioning but I must admit that I get more and more angry evertime I see an advertisement bragging about the number 1 ranking sound system by Edmunds
#139
I got the same problem: passanger door speakers blown (2).
#140
Hi again ,
Back in June they changed the right front door speaker . Now , the left one start to show same symptoms . I'm scheduled next week to change it. Hopefully the new ones are better ..
#142
anyone have center channel issues? -- I'm having buzzing under the right frequency on the center channel, right side front door, and sub. I'm reluctant to take it in because I would rather drive my car in this weather then any loaner.
#143
Yep, I am in my TSX. I've had 6 speakers replaced since buying the car 02/09 and like you said, I am not too interested in dealing w/ it all right now either so I'll wait. And to be honest it's only here and there and like you said, under the right frequency, so I may just leave it alone...not too interested in having the dealership ripping my entire dash apart for something that doesn't bother me that much. Yes I know, it's the principle of it all, but...you pick your battles.
#144
The rattling was so annoying, I went ahead and change the front speaker today.
I probably change the the speaker and sub on the back seat too. Replace it with pioneer 180w now it's sound way better than Oem.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#145
i have a 2007 TL Type S and I have noticed that the center sub in the back deck is vibrating every time the bass hits... i agree, it is extremely annoying. My vibrating sound starts about volume level 7 or 8... i have a Service Appointment tomorrow and i think that i am going to have to ask them about it...
#146
I found this in one of Acura's Service Bulletins:
DIAGNOSIS
Do the speaker check mode to isolate the faulty
speaker(s):
1.Turn the ignition switch to ON (II).
2.Make sure the audio system is turned off.
3.Push and hold the No. 1 and No. 3 preset buttons.
4.While holding the preset buttons, push the PWR
knob to on.
5.Release the buttons and the speaker check mode
begins. A test tone should sound from one speaker
as indicated on the display.
6.Each time you press the SEEK/SKIP CATEGORY
button, the test moves to the next speaker.
7.The speaker check mode ends when you turn
the audio unit off, or turn the ignition switch to
LOCK (0).
speaker(s):
knob to on.
LOCK (0).
#147
^^^ all this does is emit a high pitch tone - my speakers rattle only on lower frequency's.
Have an appointment for Tuesday to replace 5 of my speakers - sunroof rattle, back seat headrest button, rear door rattle upon closing and some mysterious click that emits through my speakers when only when my wipers are on.
#148
I get a click, quick sound of static at times somewhere from my front speakers as well, just not sure what it is or which speaker exactly
anyone ever have an issue with their sub ? last few days seems like the bass just hits like crazy and rolls longer then it did before in the past..kind of sounding like the subwoofer is going bad?
#149
in the 3+ weeks I have owned the car, my '08 TL Navi seems to have some speaker issues.
I have noticed that the key is the Dolby setting. I can have the bass cranked all the way, treble in the middle and the Dolby II setting OFF for lower volumes and ON for higher volumes. Of course, FM and XM is different than CD, tape or iPod settings.
I turned on the Dolby for higher volumes of heavier music and it never rattles. I turn off the Dolby for lower volumes, and that is the answer for me.
That said, I am upgrading when I get the sheckles. Got the weathertech's and am looking at the coldair intake upgrade.
#150
Here's a Tech Package cost perspective as to why the OEM speakers keep having issues and IMO are crap.
(2) Woofers $ 46.60
(2) Tweeters $ 41.28
(2) Rear Door $ 48.80
Subwoofer $ 83.72
Center $ 24.90
So the total cost of the 8 speakers totals $ 245.30. You can't get a decent pair of aftermarket components for that price. This is why I always go aftermarket.
(2) Woofers $ 46.60
Subwoofer $ 83.72
Center $ 24.90
#151
Boardman Acura is replacing 4 of my speakers... both front doors, the center, and the sub.
In other news, I've racked over 2k miles on loaner ZDX's and I must say I'm quite fond of the 6AT.
#152
GoBrown
Cpo 09 tl
I just bought my TL a few weeks ago. CPO 09 TL, and my right passenger speaker is blown. My Bass and Sub are on Center and it rattles on music between volume 5 and above. I am taking it in on Monday for them to fix it.
The first day I got the car and when I got home, i decided to listen to some music (volume level 8). Turns out my front right speaker was blown. I took it back and they had to order the part to replace it. I was pissed because its a BRAND NEW CAR. I think someone in the back was listening to loud music while they were cleaning the dang car.
I havent been driving much (only 700 miles) because i have been out of state. Well last night (28th day of purchased car) I decided to turn up the speakers again (volume level 10) and i hear this rattling sound. I think its my OTHER speaker. This rattle sound everytime the bass bumps just a tad, is it busted? or is something just loose?
and my tint... well thats another story. having horrible luck.
#155
CPO 09 So far they've replaced both front doors and the sub. Very common problem for Acuras and Honda's been going on for years... it's not actually blowing them it's just a defect cause some of these issues are intermitten... Crutchfield will give you the sizes it's either a 5 1/4 or 6.5 but a set of componets in the correct size with cross overs and you'll be fine... All the good brands should fit...
#156
Rear driver side speaker is blown. Taken to dealership and speaker is already scheduled to be installed tomorrow. Acura needs to step up their engineering game on speakers to match their vehicles.
#157
Just found this thread and looks like I'm not the only one. I think my sub is blown on my 2012 Tech... This same thing happened on my 07 TL-S too.... Hopefully this time around I don't get the run-around at my local Acura dealer. And no I don't listen to music loud at all. Thanks for the info guys!
#158
just picked up 09 Tech Grigio on Friday (traded in my PWP TSX for it, and i love the new TL)
mine is rattling whenever bass goes above level 4. i think its drivers side door or backseat door.
anybody know all the sizes of all the speakers in the car?
id rather replace it with good aftermarkets.
thx in advance
thx in advance
#159
If I had a nickle...
#160
Well. My front right speaker starts rattling now. The driver side speaker was replaced under warranty in 2011. I don't go beyond volume level 7. Is it possible the constant noise cancellation worn out the speakers?
