Right turn Signal Intermittent Fast flashing
9th Gear
I have a 2009 TL Tech FWD, and for about the last 4 months my Right Turn Signal flashes fast intermittently. I have checked the bulbs a few times by leaving the flashers on with and without all the lights on, and all checks out ok. Has anyone else experienced this issue with their TL's? Anyone know a fix to it if they have had the issue?
My left signal started fast flashing a few months ago. I checked and the rear bulb was dead. Maybe one of your turn signal bulbs is loose or getting ready to fail.
FFjdub96 (02-08-2016)
9th Gear
Thank you JM2010 SH-AWD for the input, I will check that out tomorrow to be sure. Maybe to time to upgrade the bulbs to something a little brighter too.
09 TL SH AWD /w TECH
Probably wiring if it is intermittent. There is three different wires going into the signal light. Maybe time to upgrade to another light like a switch back or you will need to check your wiring or maybe there is a short somewhere.
bpenn627
02-07-2016 07:41 PM
