Quick question on which greases I need for Acura Brakes job
What is the recommended grease for caliper pins and boots?
What is the recommended grease for the contact points on the pads/shim? Assuming Moly grease....which is recommended Any other thoughts like do people still use products like CRC and such for squeaks and brake quiet? Any thing else I missed or recommendations? Thanks for your time. |
I have been using Permatex Synthetic Brake Lubricant for the past few years with no issues. Just make sure the rubber boots are sitting properly after installation with some of that lubricant inside, especially the rear ones that get all the beating, they tend to seize more often than the front ones. To prevent squeaks, use some of that on the rubber on the caliper piston(s). There are tons of youtube videos on this.
https://www.permatex.com/products/lu...aliper-lube-4/ |
Originally Posted by Anicra
(Post 16035702)
What is the recommended grease for the contact points on the pads/shim? Assuming Moly grease....which is recommended Any other thoughts like do people still use products like CRC and such for squeaks and brake quiet? Any thing else I missed or recommendations? Thanks for your time. Basically anything works |
Ya I have that grease I used on my old beat up RX-7 brakes , just checking if there are specific factory crap while under warranty
no, i have not once seen a dealer pull fluids to have them tested to see if it is their brand or not
Tony, what do you mean by "the rubber on the caliper pistons"?
Please explain what you mean. In most brake jobs it is not necessary to disassemble the calipers eh. |
Originally Posted by jim_c
(Post 16040269)
Please explain what you mean. In most brake jobs it is not necessary to disassemble the calipers eh. https://s29.postimg.org/gwubisp1j/70...0000028364.jpg (just a pic I found on the net to point out what I mean) |
