Power Outlets not working after shortage
Old Jan 5, 2016 | 11:41 PM
smokinacura's Avatar
I was using a power inverter with a heavy duty object( i guess an induction coil is heavy duty) and all of a sudden the port stopped working, I switched ports , and it shorted out a second time and now neither power port is working
I don't know where the fuse box is or which fuse goes to the power outlets,
any guidance would be appreciated... please.
Old Jan 6, 2016 | 10:04 PM
TheDingo's Avatar
Resident Dingo
There's a fuse box under the driver's side of the dash, and another under the hood. Each of those have a directory on the lid that will tell you what each fuse does. Pull those covers, find your culprit and replace.
This kind of goes without saying, but make sure you replace the fuse with the correct (same) amp rating as the one you pull out.
Old Jan 7, 2016 | 05:47 PM
ucf_bronco's Avatar
There's also an interior fuse box on the passenger side. One of the fuses you need to replace is in that one (no 16) and the other is in the fuse box on the driver's side (no 23). Both of them are 15A.
Old Jan 7, 2016 | 07:07 PM
TheDingo's Avatar
Resident Dingo
