AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   4G TL Problems & Fixes (https://acurazine.com/forums/4g-tl-problems-fixes-297/)
-   -   P0507 code - (https://acurazine.com/forums/4g-tl-problems-fixes-297/p0507-code-936089/)
Big mo Sep 11, 2015 08:56 PM
P0507 code -
I have a 2009 tl-Shawd and received a code P0507 after I cleaned out the throttle body with CRC throttle body cleaner and cleaned the MAF with CRC MAF cleaner. The same day I noticed an increase in parked idle speed and general acceleration which I was impressed and happy about but then a few hours later the sh-awd error light and emission error light came on. I disconnected the battery after a day hoping it was just carbon build up form the cleaning but code is still coming back up. Also I noticed it will go to front wheel drive mode only and I have to restart the car to get and again. Anyone know what this code is for and how to fix?
EE4Life Sep 11, 2015 09:06 PM
See article "MIL On With DTC P2279 or P0507 After Throttle Body
Servicing" on page 5 of the June 2013 Acura Service News.
https://acurazine.com/forums/third-g...8/#post8398357
Big mo Sep 11, 2015 10:12 PM
Thanks for the info! Now i just have to figure out how to implement the fix.
Tonyware Sep 12, 2015 07:22 AM
If you don't have access to the Honda Diagnostic software/system.... based on past experiences with a J30 engine on an Accord, to fix this you need to do a couple of long deceleration (preferably on highway off ramps) with your foot off the gas. Shut it down/start it and after it cools down a few degrees get back on the highway and maintain a steady normal-highway speed. Sometimes the idle gets fixed like that and the ECU non-continuous emissions tests set the codes right and re-writes values in memory such as the throttle body valve position. Also, run the engine and let the fans start/stop twice, even though sometimes on the 4G TL, the 3.7 engine, won't heat up enough (over 90oC I think) for the fans to turn on.
Remember safety first, don't do any of these if there is traffic or you have drive ability issues with the car.
© 2026 MH Sub I, LLC dba Internet Brands
