Need help removing fuse panel
Old 12-17-2017, 02:58 PM
sunshne078's Avatar
Hey! I’ve got a ‘Check VSA System’ light on and want to check the fuses in the fuse box under the hood, but I cannot pry it out. I removed the screw that appeared to be anchoring it, but what’s the trick to prying it out? I feel like an idiot.
Old 12-17-2017, 04:55 PM
sunshne078's Avatar
I should clarify that I’ve got the fuse box open and I’m looking to access the bar of fuses dealing with VSA and ABS. I’ve chipped the plastic trying to get it to pop out.
Old 12-25-2017, 01:10 PM
grandlaker's Avatar
Just popped mine out this morning. On right side there is a small clip you need to disengage and then I used pair of pliers and pulled straight up and it popped right out.
TheyGotMawty
02-20-2017 05:59 PM
know610
01-21-2017 05:21 PM
rick sambora
05-11-2013 05:52 PM
kris10950
10-07-2008 05:02 PM
Panda_TSX
1G TSX Problems & Fixes
01-02-2006 03:52 PM
Quick Reply: Need help removing fuse panel
