Misfire codes plus hill assist, vsa, sh-awd, emissions
1 Post
hello,
been reading up on a problem I’ve had with my TL. 2010 6 speed manual 140k
after getting some paint touched up, the body guy let the vehicle sit on a hill overnight. When I picked it up I got the so-called Christmas tree lights of hill assist, emissions, vsa, and check sh-awd. The car seemed to drive fine. After clearing the codes, all has seemed fine the past few weeks. I chalked it up to maybe a low battery charge or because it was parked on a hill overnight.
Today all the lights came on again as I was exiting a slow decline Parking lot.
The codes exactly are p0300, p0304, p0305, p0306 and all wheel drive 77 and vehicle stability assist 83.
the spark plugs were changed by me about 3000 miles ago, and the timing belt about 4000 ago by a local shop.
I have been thinking it’s time for a valve adjustment as it seems to be slightly noisy. Could too tight valves be causing the misfire codes? Coil packs maybe since the codes seem to be on one side?
1 Post
So hooked up the scanner and still showing misfire on cylinders 4,5, and 6.
it also showed a pgm-fi malfunction and a clutch pedal switch b malfunction 118-01.
The plot thickens.... I’m going to inspect the wheel sensors and replace the egr valve.
1 Post
Both the battery and alternator passed their tests with a voltmeter, but feasibly it could be a bad ground somewhere. Not sure where to even start looking to track down a bad ground
I disconnected my EGR valve the other day to diagnose an issue and my SH-AWD light came on, so don't read too much into all of those warnings. I seriously doubt parking on a hill would cause any issues.
Battery
