Loud Humming Sound
Old Dec 21, 2022 | 06:45 PM
Zz916zz's Avatar
Loud Humming Sound
2013 TL FWD
Trying to find some help determining what’s causing this humming noise from the engine area. Lasts couple mins after shutting off car.
https://youtu.be/epWuaYF4ZmY
Old Dec 22, 2022 | 08:32 AM
NDNV's Avatar
Some possible causes:
  • fuel pressure regulator
  • A/C compressor and expansion valve
Old Dec 22, 2022 | 08:04 PM
altair47's Avatar
The pressure regulator is located in the fuel tank, the AC compressor is mechanical, it does not work when the engine is turned off
Old Dec 22, 2022 | 08:17 PM
altair47's Avatar
Originally Posted by Zz916zz
2013 TL FWD
There are only 3 electric motors under the hood that can make this noise.
1. Throttle Body.
2. IMT activator on the intake monifold.
3. Steering rack and pinion.
To localize the noise, first try to disconnect the IMT activator
Old Dec 22, 2022 | 10:28 PM
Zz916zz's Avatar
Thanks for the response. I’ll give that a try tomorrow
nollid
Dec 3, 2012 08:59 AM
sufall96
Dec 19, 2004 10:01 PM
Casey TSX
1G TSX Problems & Fixes
22
Jun 27, 2004 03:53 PM
