Hissing Noise from Front of Engine
Old Aug 29, 2016 | 10:49 AM
mossman77's Avatar
I noticed a hissing noise coming from the front of my engine while testing the PCV valve yesterday. It was hard to pinpoint, but it is definitely coming from the front near where the ignition coil wire assembly/protective cover mount to the motor. When I pinched the hose on the left front of the motor, the hissing decreased. Is this normal? Perhaps I am hearing hot gases passing through the passage leading from the hose to the PCV valve? Also, the PCV valve doesn't click when I pinch the tube, at least I cannot hear it. I did get a check engine light for the emissions system after doing so though.
Old Jan 11, 2026 | 09:26 PM
GOOSE3612's Avatar
7th Gear
I know this post is old, but I'm searching through and finding the same issue on my TL. Hissing noise and fast idle. If I pinch the PCV hose, the idle drops to normal. Otherwise I get an erratic idle, and a P0507 High Idle CEL. Did you eventually fix this?
Old Jan 12, 2026 | 07:19 AM
altair47's Avatar
What's preventing you from locating this air leak by noise?
You haven't replaced the valve covers recently, have you?
Old Jan 12, 2026 | 10:08 AM
GOOSE3612's Avatar
7th Gear
yes, i did do the valve covers. they were cracked so i bought new ones.
Old Jan 12, 2026 | 08:11 PM
altair47's Avatar
Easy diagnosis. Your valve covers are junk, buy new or used OEM ones.
Old Jan 13, 2026 | 08:49 AM
GOOSE3612's Avatar
7th Gear
yah, that's my thought too. fucking a.
furnac3
Aug 20, 2024 05:01 AM
furnac3
4G TL Problems & Fixes
Apr 7, 2024 09:33 AM
Acurian24
1G RDX Problems & Fixes
Aug 15, 2016 10:54 AM
hondapowered316
Jul 20, 2015 11:40 AM
t0talacuratl
Jun 10, 2015 10:15 PM
