gas filler door not flush with body
My gas filler door is not flush with the body of the car. It is out on the hinge side about an 1/8th". It is equally spaced all around but not flush. Does anyone have this? I did press in firmly on the hinge side and was able to reduce the amount so it is not as bad now. I first tried prying off the plastic screw cover near the hinge and I loosened the screws and tried to make adjustments, but they are left/right up/down only. I could not figure out how else to make the door move in to be flush. I could actually see it when looking in the side view mirror. It is also out a little on the latch side. Run your finger across and see if you guys have this. Thanks.
Mine is perfectly flush. I'm really impressed with the fit and finish of exterior and interior
I'd let your dealer take care of it.
rockyboy
12-06-2022 02:29 PM
09-17-2015 09:01 PM
09-04-2015 08:03 AM
