Electrical Problem
My navi, radio and 12v outlets all don't work. I have checked fuses and they're all good. I replaced the battery as well. Is there anything else I should check?
How did you check your fuses?
Yes I checked the fuses and replaced the 2 gray relays in the driver side fuse box. They're all good.
Did you check the fuses with a continuity meter?
I will do that when I get a chance to. Does the radio have a fuse behind it?
