Driving Experience with AWD question
For you AWD owners....
This is an opinion/question as to how my 6 speed transmission operates. I've put 25,000 miles on my car since I purchased it in March 2015. I've noticed this since day one, and assumed the transmission needed to learn my driving habits. However, I want to know if my description below is normal for us AWD owners....or if I have a mechanical issue perhaps. I understand we're over text and driving helps...but its straight forward. Current mileage, 51,000.
1. First gear into 2nd gear. - accelerating under normal "follow the pace of traffic" conditions, the transmission DROPS into 2nd gear and takes a bit to move to 25-30mph. If I go WOT, it will move, but lags. I am considering that perhaps the design in the 6 speed was intended to be this way....its not as quick as my 2009 TL FWD was with the 5 speed. Thoughts ?
2. After reaching 40mph.... the tachometer fluctuates 200-300 rpms until it reaches a higher speed. This is more prevalent on the upgrade hill or consistent gas pedal pressure in traffic. Almost like the car shouldn't have shifted into 6th gear. Always happens on automatic...not S mode/paddle shifter. Thoughts, anyone?
3. Transmission oil filter was replaced yesterday. Would the clogged filter have restricted transmission in any way to cause the issue above?
4. Acura Technical Mechanics cannot duplicate the problem . . .But its obvious to me.
Are all of these descriptions normal as the car was designed?
Appreciate you AWD owners chiming in to confirm. Im not looking for a problem...it just seems odd to me. I know the car is heavy as well.
Thanks.
Thanks.
I notice the same thing you describe in #1. Going from 1st - 2nd at a low speed, conservative throttle, it will kinda dump itself into second like it shifted too early in a weird way. Hopefully its not a problem, i don't think so, but I could be wrong. I've just learned to live with it.
Edit: 2012 TL SH-AWD
Turns out TSB 16-030 is a possible fix. If that does not work, after some continued driving, then TSB 16-040 may be the solution. I'll repost with the results to help others with similar issues. Won't have this relearn software update until the end of the month.
Classic Symptoms of a failing torque converter! Take a video of the RPM fluctuation with your phone to show the dealership.
Have you changed the transmission fluid at all? It should have been replaced around 30K miles.
MID never showed anything for the transmission service before, and thats what I go by since the car is ALL highway miles.
Its crazy. I'll let them play with the software update, but Its not my first car. I've known the TC is failing, and now the fact that a TSB is out on it, plus warranty extension . . . just replace the TC please :-)
