Door is Crooked....
Door is Crooked....
I didn't notice this until about 2 days after I got the car but the drivers door is out quite a bit. I took to the dealer and they're ordering me a new door! Anyone else with this problem?
Make sure they get it right and I'd put in a call to Acura, or you can wait for the online surveys to report your issues. Dealerships have been messing up own beloved 4G's as of late, so watch them carefully.
i have the same thing on the driver side. i would leave it alone. i dont want new doors they never will match the paint and if u ever sell it they would think car was hit or painted for reasons.
I'm not really a big fan of having spent $40, 000+ on a car with a crooked door. They will fix it until they get it right...
i had the same problem, but mine was the trim on top of the door that wasn't level, they ordered a new one and fixed it immediately.
looks like yours is a little more than just trim though..
They tried to adjust it. It's like the door is some what indented because it is only off in that one spot pictured. the rest of the door is fine. It seems that everyone is having this problem. Maybe Acura is going to have to do a recall!
I am a bullet proof tiger
just checked mine out and I have the same issue. I dont want a new door, but now this is annoying me. Interested to see if there is a fix besides replacing the door.
I have the same issue and made an appointment with the dealership to take a look at it. I was wondering if the dealership replaces the door, will it show up on your car history report (i.e. carfax)? Will it seem like an accident on the report or will it have a detail description of what was done (i.e. manufacturer defect)?
This looks like something bigger than an alignment issue. The perimeter of my door is aligned perfectly to include the window frame. The real problem appears to be the door size is designed and/or manufactured incorrectly.
I have car ADD
yea, saw a 4G parked today, took a peek.. same thing
must be a design flaw.... recall? highly unlikely... unless its proves to be dangerous
... "the abrupt change in wind-flow and aerodynamics was caused by the gap in the door.... causing me to swerve and crash the car".....
Probelm will be when you sell car they will know the door was replaced and could make trade or resale harder, if you plan on keeping it 5+ years that is fine, but I woudl leave factory panels along. I bet the blend the paint into the front and panel and rear door thius having paint on those panels as well.
I too noticed the same problem with my first 2009 SH-AWD, in fact not only was it noticeable on top but in the bottom by the under spoilers, the door was a bit outward after closing it. I'm in a different SH-AWD and this one seems to be buit completly different, everything aligns just right. I think the fix is in the hinges but I'm not expert.
Yeah I'm interested to hear the reasoning as well...our drivers side front door was crooked as well....we noticed it and they told us to bring it up immediately....they worked on it for awhile and discovered the trim on top of the door was what was off, not the door itself. They ordered a new peice of trim and had it put on ASAP...they also replaced our drivers seat, the stitching rubbed against the seatbelt and had started to come apart..
I brought the car in for service and mentioned about the crooked door. Dealer said its the design and all the TL's were like that. I checked the ones in the showroom and the ones parked outside and all were like that...
Took my 4g in last week and the dealership was able to correct the trim alignment issue. They said they just removed the chrome piece and reattached. Looks perfect now.
8th Gear
Minor issue, I wouldn't worry about it. Factory is factory. It doesn't affect anything other than the keen eye of the owner. I have it, I don't care about. I don't think anyone else should either.
At first I thought it was hit in the lot and the dealer fixed it up by going to a body shop. It seems the passenger side is assembled/built so much better. With Acura's claim to fame for their quality I find this unbelievable that Quality Control would let this go out the door.
Being a Mechanical Engineer that used to be in the car industry I would not accept a new door by Acura only to have it painted by some local body shop. NOTHING matches the quality of the factory paint process let alone matching the paint. Hot phosphate bath to degrease, ionic charged primer process, baking process, blah, blah, blah. I highly doubt any body shop will have the means to do that.
Also, the other situations that others have posted may be resolved with hinge adjustments but I doubt ours can. If you adjust the lower corner to be flush, the top bow will be more pronounced. From my assessment this afternoon it seems that one of more of the sheet metal was warped when they were welded together to form the door box construction.
I'm glad that I'm not the only one and that it was not a hit and repair job by the dealer.
(BTW, great forum. The best I've found on the net. Lot's of catch up reading to do. )
to be honest, this is on my 2006 CSX, 2006 TL and now that we're picking up the 2011 next week. i would expect the same. lol. but as someone mentioned already, it's more of the plastic frame not matching and less of a door issue. and also, not sure if this makes sense but the front fender should be slightly outward compare to the driver door, and the driver door is slightly outward to the rear doors to avoid wind noise from getting into the seams...its the exact same on my GLK cept the plastic is aligned properly but that car's got issues much more than misaligned trim, lol
Mine is the same.. noticed it on test drive..
Oh well i am not changing anything to try and fix it..in fact i have a few panels that do not seem to line up perfect liek on my bmw or even my scion for that matter.
must be part of the american made part..
soupi
14
11-15-2015 11:15 AM
