"Clunking diesel noise" when starting 1st/2nd gear.
2010 TL AWD 6MT: New King
Occasionally I've been now noticing the following noise occuring: after I've driven the car and the car is warmed up, I stop, shut off the engine, and leave the car. I return sometime later, say 20-30 minutes, and:
I turn on the car, and accelerate in 1st gear (starting from stationary) I can hear what appears to be a "diesel clunking like noise" that appears to be coming from the engine bay. I can hear this noise in 1st and 2nd gear, and appears to have disappeared by the time I'm in 3rd gear or higher. If I stop the vehicle, and continue on in 1st and 2nd gear again, I hear the same "clunking noise." This noise seems to be disappear if the car is driven for a bit. If memory serves me right, I recall hearing this noise when I'm starting of on an incline.
Have you guys/gals heard this "clunking noise" before? The first time I've noticed this noise a few months ago, I thought an engine part may have "broke" and I'm driving a tractor trailer.
I have a feeling though, they won't be able to reproduce this noise and say it's driver error (like my 3rd gear occasionally popping out).
Thanks for the response. I'll mention this noise to the stealership tomorrow. Would you know of any possible causes? I always use 91 unleaded FWIW.
If you ever had an old standard car and when in econd gear driving throw it into 5 th gear and hit the gas it makes the tranny clunk bc the engine speed is not matched to gear speed. There is a term for that. And to me that's what it sounds like. Tranny lug, ,that's the term I think.
Let me know what they say. I have this too. Pinging is not it, I have had that in other cars, the ping is much more high pitched. Diesal sound come to think of it is accurate. I get it when warm, when gears 1 or 2 are under load. I took it in one for it and they could not reproduce. Then they just said its normal. I've al wys been sure it isn't.
Do you also have a 4G TL 6MT?
I had an old 91 Integra 5spd manual which never made this "diesel noise." I haven't had time to call the stealership yet. I'll see if I can get around it today.
Can you describe what "pinging" sounds like? I always assumed it was like a higher pitched, fairly rapid, "ting-ting-ting-ting-ting" sound that I sometimes hear after the vehicle is driven for a while and it sits in the garage.
I've never heard pinging being high pitched. If its NOT pinging then it could be a rod bearing. Have any of you run low on oil at ANY time? Maybe what you are hearing is the torque converter issue. Do you have AWD?
Yes, I have a TL 6MT, which is AWD. Does the torque converter issue affect manual transmissions as well?
I heard it again this morning, when I was driving up a small hill. Doesn't happen all the time, and I'm pretty sure the stealership will says its driver's error or "within specs."
It sounds like spark knock ("pinging"), especially when you describe it as happening going up a hill. Pinging is usually worse under a light load.
Could be a bad batch of gas or your spark knock sensor is not working.
I'd take it in. Pinging is not good for the engine over the long run.
I'd be very surprised if it's a rod bearing. It's a HONDA. I've seen Accords that have gone years without oil changes, only having oil added when the light came on. Even these cars experienced no rod bearing failure.
I also have this issue. 2010 6MT SH-AWD (obviously)..
However, today I really noticed it starting out in 2nd gear. I also found out the wife put regular grade gasoline into it on the weekend.. tsh tsh.. She now knows not to! I'm hoping that when I fill'er up with premium again, it will subside..
My transmission is much more of a problem than the 'diesel knocking'. It frequently grinds on it's way into 3rd (clutch to the floor as a habbit now from this problem), and if I'm redline in 1st then slide to 2nd I can hear a metallic grinding from the synchros (especially if the windows are open and there is a reflective surface such as a curb near by). A few weeks back, I couldn't even get it into 1st gear at all. I took it to the dealer, but of course by time I got there it was smooth as butter again.. Not happy with this transmission so far, unfortunately!
Anyone else have this issue?? Sorry to hijack your thread!
I'm hesitant to try the GM syncromesh fluid. Seems to work for the 3G TL, but 4G shows mixed resuts. One 4G owner used it and I think it really messed up his transmission.
I have also heard the infrequent "screech" when shifting from 1st-2nd. Not very pleasant.
Stuck at this point on what to do....
Not so sure while under warranty with the issues I'm having this would be wise. Today, redline from 1st to second it wasn't in any mood to engage! Needless to say, it no longer goes into 1st gear!
So, it's 100% of the time 2nd gear starting for me until the dealer fixes the transmission. No matter what I try, can't get into 1st whether I'm stopped or rolling. POS..
Anyhow, we'll see how this one goes over with Acura.. Silkysmooth OUT.
6G TLX-S
With the shift stick in neutral, try let up the clutch for a few seconds. This will synchronize the engine rpm with the tranny gears. Then depress the clutch all the way, and see if you can shift into 1st this time.
Better fuel economy starting off in 2nd anyhow :-)
6G TLX-S
Looks like you've lost 1st gear synchronization completely. You may need to rebuild your tranny to fix.
She was dropped off this morning at the dealer. We will see what they say.. dealer says he's gonna take it for a test drive. LOL. Why bother when it doesn't go into first!
Tranny will be coming out for rebuild. I plan on stopping in tomorrow to see the progress, and more importantly the problem!!
Leather so soft.
i have a 2012 manual tl, and i encountered this problem too? did you find a solution orthe problem?
Hi guys ,
I am having the same issue started 2 weeks ago ( every fluid in my car is flushed new with synthetic last month and car is up-to-date) ***09 SH-AWD AUTO***
Took it to dealership. Tech took it for test drive he said its loose heat shield
I Checked everything under the car nothing loose,
took it back to dealership took out their most experienced Tech for drive
he said its pinging and its a bad batch of gas as I use 91 gas from Superstore all the time. Told me to use SHELL V-POWER for next 3 for 4 tanks as its a slow learning process for ECU
or he also gave me a option to use the rest of gas and fill up with V-power and come to dealership and get the ecu updated to tell it that its ACTUAL 91 OCTANE GAS
I just filled up my first tank with V-POWER let see how it changes
I have noticed if I don't accelerate hard it won't do it hopefully its just engine knocking.
"Lastly damage caused by using cheap 91 gas( there is a engine code for low octane gas used multiple times) is not covered under warranty and it eventually causes engine light to come on which can be a serious issue( that means ECU counts the cycles of knocking where it had to retard timming when it reaches certain limit it gives check engine light)" - AS TOLD BY ACURA SERVICE MANAGER
hope it helps :-)
hope it helps :-)
Keeping TL until 2029
I recently switched to Shell. If it can go in a Formula 1 car, it's good enough for me.
http://www.jamesallenonf1.com/2011/0...road-car-fuel/
Not sure if its the same sound... but I had noises coming from the heat shield and I realize its not directed related to the tranny but on my car it had a sweet spot... 2nd or 3rd gear at about 2300rpm. The noise bothered my so much that I literally drove the car about 100 miles on a Saturday to find this sweet spot because as you know... if tech can't hear it... tough luck!
The heat shield was bent out a bit and it also had some pebbles in there that were rattling.
“99% of the chemistry in Shell V-Power race fuel is identical to the chemistry used in the road fuel that can be bought at Shell forecourts
When I'm at idle, like at a stop light, I'll notice this faint clacking noise from the engine bay, which reminds me of the clacking of a diesel engine. I presume it's a belt? I'm surprised I'm hearing any noise from a higher end car like this.
[QUOTE=docboy;14067155]
QUOTE]
You can rule out torque converter, you have a manual trans., that means, no torque converter...only in automatics.
THIS might be the torque converter issue, loss of power on acceleration?
Any early AWD automatic TL with this issue should be checked for the torque converter issue...I believe there was a TSB (Technical Service Bulletin) with Acura about it...they should fix it.
QUOTE]
Hi guys ,
My starter with only slight clunk just like ok stated but turned into this. To make the long story short, dealer is replacing the entire engine. They said it was a bent rod or something like that.
T20131015_185612.mp4 - YouTube
marcelft
07-10-2018 06:17 PM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
mugen_kid
11-13-2015 10:38 PM
