Check DRL (daytime running light) System
Old 11-21-2018, 02:30 PM
5th Gear
Hymen Chu's Avatar
Hello,
Recently my Acura 4g TL started to give me intermittent an orange 'Check DRL System' light on the dash. I've had LED DRL installed for a while with no issues. I checked all connections and all were tight/ connected. I should mention that the LED DRL stays on during
The light only comes on at a stop, it goes away when i accelerate. It comes on sporadically which makes it annoying because it beeps everytime. Doing some research, it sounds like the 2g/ 3g DRL module has weak solder points so i tried to find the DRL module in my TL 4g to see if i can add some solder; but i couldn't find the module under the steering column.
Anyone had similar problems, and know where i should go from here? Where is the DRL module in the 4g TL exactly? Next i was thinking about switching out the LED DRL but i don't believe that's the problem. judging by how its intermittent based on driving, i believe it might have to do with a connection or a solder connection.
Hymen
Kaywhy201
ILX Performance Parts & Modifications
01-29-2019 09:56 AM
Ruben Espinosa
12-21-2018 11:26 AM
Quick Reply: Check DRL (daytime running light) System
