Car won't start... Help!!!
Old Aug 21, 2013 | 01:09 AM
fozzythebear's Avatar
8th Gear
I have a 2011 acura tl sh-awd. Was washing the car today, after I was done, I tried to start, no go, just the clicking noise. I did not wash anything in the engine bay. I changed my oil and rear differential fluid yesterday, drove around today no problems.
I tried to jump start the car with a jump pack, no go, just clicks. The brake pedal feels extra stiff when i press the push to start button. Headlights turn on, no flicker or dimness.
any ideas?
Old Aug 21, 2013 | 01:57 AM
potmilkz's Avatar
try sticking in the key to the slot and starting it.. maybe your key is not reading with the car..
if that doesnt work, disconnect the battery wait 30 secs and reconnect it.. see if that would work
Old Aug 21, 2013 | 11:43 AM
8th Gear
I tried the key thing yesterday, no go.
I tried disconnecting the battery this morning, still no go. The weird thing is that accessories still work. Would the brake pedal being heavy indicate that there is some kind of security measure with the alarm to disable push start?
Old Aug 21, 2013 | 12:23 PM
potmilkz's Avatar
sounds like a dead alternator or starter... if your car is still within warranty i would call acura and have them come and tow the car for you for free.. just make sure you dont have any aftermarket electrical on the car like a aftermarket sounds system.. or else they will start playing the finger game with you
Old Aug 21, 2013 | 09:43 PM
8th Gear
I was able to jump start the car from my brothers car. I guess the 450 amp jump pack is not enough to get the TL going. Now I am getting flashing error messages,
Check VSA system
Check ABS system
Check Hill Start Assist System
And the indicator lights on the dash are on for those items.
Anyone familiar with this problem? I will bring it to the dealer tomorrow. I have not installed anything aftermarket, everything is stock.
Old Aug 21, 2013 | 10:37 PM
gkon's Avatar
I'm guessing battery, my MDX did the same thing, but I was able to jump it (without error messages) and get it to work temporarily. But I had to get a new battery.
Old Aug 22, 2013 | 09:07 AM
Takehold66's Avatar
^+1 - Get a new battery - had the same symptoms when my car was only 2 years old. Got it jumped and then replaced the battery with one from Autozone. Problem solved.
Old Aug 22, 2013 | 12:03 PM
8th Gear
Went to the dealer today to check it out. They tested the battery said it was fine, reset the codes, and everything went away. Very strange, and no real explanation from the service guy. I detached the battery for about 5 minutes the other day and the codes were still there.
Old Aug 22, 2013 | 12:40 PM
dwest1023's Avatar
If you had the radio playing while you were washing the car, it will kill the battery. If during the winter you find your car starts slowly, replace the battery. Its not good to run a battery down to the point it will not start the car.
If you did not have the radio on or any accessories, then I would replace the battery now.
Old Sep 18, 2013 | 09:32 PM
Acura_Swag's Avatar
that's weird bro. but then again you got a new car it should be under warranty if its still stock, I would let the dealer deal with it
Old Sep 19, 2013 | 06:18 AM
Advancebo's Avatar
I had the same happen to me about a month ago. I had to jump start the car many times a week.
My mechanic thought it was the positive terminal wiring harness, so I bought a new one from Acura for ~$70. I still had starting problems a few days later. Then he checked the water levels in the battery, and some of them were low, so he leveled it out. Still had problems later again.
I ended up replacing the stock battery with a $120 Duralast battery, with $15 trade in from the old battery. I made sure to get the one that has more than 700 CCAs.
This was on a 2010 TL SH-AWD.
Old Sep 19, 2013 | 10:45 AM
potmilkz's Avatar
battery is known to have a issue for these 4th gen tl.. let alone the whole acura line up.. my battery got replace the first 3 months of ownership back in 2010.. but never happened again.. i guess when a battery is not being used as the car sits on the lot for days or even months it does die out
Old Sep 19, 2013 | 03:33 PM
JM2010 SH-AWD's Avatar
As others have said, it's your battery. Mine croaked suddenly just like yours after about 2 years.
Old Sep 19, 2013 | 03:48 PM
3.2TLc's Avatar
Yeah, all the power accessories take a toll on the battery. Almost everything has a trickle scavenging drain on it. Replace it with the best ya can afford and keep the warranty documentation for future reference. A weak battery is hard on the alternator and the entire electrical charging system. Replacing it will give ya some peace of mind and cheaper than an unexpected breakdown.
Old Sep 19, 2013 | 03:51 PM
Xxb005txx's Avatar
Gabriel Alejandro Iser
try turning the key while pumping the accelerator and turning the wheel back and forth? could be your battery isnt running on the full voltage needed, or your alternator is bad and is draining your battery to start your car.
Old Jun 14, 2017 | 05:33 PM
RICHDAKIDD's Avatar
I know this is a old post but I literally just ran into the same exact problem as fozzythebear has described. Is there anyone with any additional updated information regarding this issue??? Please help as I'm stuck stranded out of town atm. Thxs, Rich.
Old Jun 14, 2017 | 09:33 PM
Pretty sure it's your battery. If you scroll down from the top, that turned out to be the OP's problem. Good luck.
Old Jun 15, 2017 | 12:46 AM
RICHDAKIDD's Avatar
My car battery or the remote?
Old Jun 15, 2017 | 12:19 PM
echodigital's Avatar
From TL to RDX
I bet it's a bad 'car battery'.
Old Jun 15, 2017 | 12:22 PM
the car battery usually has a little sticker that has the month and year on it.
if the sticker indicates 3 years or older, it's time for a new car battery
Old Feb 12, 2018 | 09:49 AM
zmt's Avatar
zmt
Ran into this today. I figured it was the battery too, so I replaced it with a brand new duracell from Sam's. Same behavior with the new battery. Press button, I hear the relay click, but nothing from the starter at all (at least nothing I can hear). Weird thing is it was the 2nd start of the day, 1st start in my garage was fine. Has anyone had any issues with starting that *aren't* the battery? I'm not getting any low 12V warnings on the dash or anything. Just nada when I try to start the car. Accessories and everything work fine like some of the others have posted.
If my fob battery was low, would the starter relay still click over? I would assume not and that the car would ask me to insert the key right?
Old Feb 12, 2018 | 12:03 PM
RICHDAKIDD's Avatar
Just a quick Update/heads up to anyone that’s came across this problem. So it seems it was a main fuse that interacts with the pushstart button. It was replaced and all was fine, at least that was my problem/issue at the time. Hope this helps.
Old Feb 12, 2018 | 12:07 PM
zmt's Avatar
zmt
Wanted to add that by starter I meant solenoid. It's early and "cold" in Texas so my brain wasn't working so great. Sounds like strong engagement from the solenoid but nothing from the starter. I'm probably gonna double check my terminals and all the grounding tonight and see if there's anything wrong before moving on to ordering a new starter. Seems weird for it to go out in 6 years/72k miles or so.
Old Feb 12, 2018 | 12:09 PM
RICHDAKIDD's Avatar
BTW does anyone know a good brand replacement battery/brand? I’m need to replace mines soon.
Old Feb 13, 2018 | 10:22 PM
zmt's Avatar
zmt
So my problem ended up being the starter. Here's a video of what the original starter was doing:
You can see/hear that there's a major voltage drop when engaging the solenoid and not just the motor. I don't know what was causing it but the replacement tested out just fine, so I put it in and the car fired right up. Just a heads-up for anyone chasing starting issues. If you hear the solenoid clunking but no engine turning over, it may very well be the starter.
Old Feb 18, 2018 | 10:58 PM
Anicra's Avatar
Thats like dealer's choice. Everyone has a favorite due to price , availability or certain performance ratings. For some people getting a new OEM battery due to long warranty is the most important. I live in the cold so CCA is what I aim for. Usually most I can find. Now I have a car cam that drains my battery to 12.3V then shut off in park mode. I used to put in Interstate Megatron Plus (not the Megatron II). Due to repair shop up 3 blocks away - can get fresh new battery off the interstate truck within hours, their prices are dirt cheap for a MTP 24 and easy 800CCA for the cold winter months. I have owned 5 Interstate Megatron Plus and all I have lasted with no issue even after 5 years. Generally I usually just replace the battery after year 3 or 4. Since I have something constantly draining the battery I switched up to deep cycle battery. So I gave Odyssey Battery a try since there is a dealer within a mile. I went with 34R-PC1500T with a spacer. I got a deep cycle battery with 850CCA.
Some people like Exide, Walmart, Costco, Interstate, Optima or many others. Pick whatever sorts your needs. If you live a warm climate the answer is usually far cheaper.
Old Feb 18, 2018 | 11:02 PM
Anicra's Avatar
IF you get bored - Blow out the fuse in the rear view mirror (it is number 13 driver side) and now your car will not start. If will crank and sound like it will start and it might for 2 secs but it wont stay running and turning the car to off on push button start becomes a major pain.
ssjkev16
Dec 22, 2024 02:51 AM
Feb 25, 2020 09:57 AM
bymotion
Aug 31, 2015 05:00 PM
