The car will not start
Old 10-30-2017, 02:31 PM
RCANTRELL's Avatar
i left my 2013 acura tl running then it shut off and it wont start now
Old 10-30-2017, 02:37 PM
Keeping TL until 2029
echodigital's Avatar
Battery?
Old 10-30-2017, 02:39 PM
RCANTRELL's Avatar
It looks like there is a blinking light on the dash. I thought it might be a silent alarm.
Old 10-30-2017, 03:24 PM
losiglow's Avatar
Yes, the blinking red light indicates the immobilizer is active. Does the accessories come on and the screen display the insert key error (assuming you have push-start). Or is everything more or less acting dead.
Old 02-26-2019, 07:54 AM
3rd Gear
Acuranoobb's Avatar
Hi
Im having this same issue. Am getting no power and everything pretty much dead. Only horn and hazard lights work. There’s a small circular red light blinking on the dash cluster. Any clues?
Old 02-26-2019, 11:13 AM
losiglow's Avatar
The small red light on the dash is the alarm indicator. Replace the battery in your key fob. Or try inserting it into the slot. That's assuming you have the Tech or Advance trim.
Old 02-26-2019, 11:41 AM
3rd Gear
Acuranoobb's Avatar
Its the tech. Replaced the fob battery and inserted the key with no help. Brand new car battery too.
Old 02-28-2019, 02:41 PM
3rd Gear
Acuranoobb's Avatar
TL with no power
any suggestions for a cause or issue? Dealer said it was the battery terminals but the problem is still happening
Old 03-23-2019, 08:52 AM
Pless4's Avatar
No power
I watched a you tube video about jumping slot 4 and 9 on the ecu plug to reset the ABS and VSA lights on the dash when I connected the wire to those ports I shorted out everything inside the car no power everything in the engine compartment fuse box looks good any ideas about what BLEW or what fuse it might be
javamanbill
02-04-2017 11:27 AM
navicolb
11-08-2016 12:43 AM
berkeleysquirrel
5G TLX Problems & Fixes
10-10-2016 07:18 PM
Eggplant-EX
12-26-2001 10:48 AM
Quick Reply: The car will not start
