Can anyone on ths board look up a TSB?
I searched and searched for a TSB on the rear shelf/sub etc rattle, this is with any sub bass at all. I found a site that lists all TSBs and this one gives a number and when, however I can't see the details of it? Anyone on here able to find that information and be able to print it? Here is the number and info I found?
10-027 AUG 10 Audio System - Door/Rear Shelf Speakers Rattle/Vibrate
YOU can do it.
Here: https://acurazine.com/forums/4g-tl-2009-2014-123/4g-tl-technical-service-bulletins-tsbs-701767/
Follow the instructions at the top of post #1.
If the TSB you're looking for is not listed, just open a random TSB, then in the address bar replace the TSB ID number with the number you need.
YOU can do it.
Here: https://acurazine.com/forums/showthread.php?t=701767
The 3G TL had something like that (deck rattle). It had mutliple causes and extended across the entire 5-year production cycle. Perhaps it made it the 4G too.
http://techinfo.honda.com/Rjanisis/pubs/SB/B04-043.PDF
I think the description at your referenced site is incorrect or mis-leading.
ExcelerateRep
10-14-2015 08:20 AM
