b14 service code 2009 tl
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I just received a maintenance minder for my TL and I am aware it is time to change the timing belt. Is it also recommended to change the water pump during this scheduled maintenance?
yes, you should change the water pump, idler pulleys, spark plugs, and perhaps a valve adjustment if they are noisy.
jreg (07-07-2015)
Id go OEM all the way for that. Not sure where your at but Honda is running a special in my area 569 for a 6 cyl including pump. Curious... How many miles are on your TL? 60k or around 100k?
I would jump all over that special even if I had to change it before it was due.
mada51589
05-03-2022 08:54 PM
jamestheunderdog
07-19-2016 07:58 PM
