Anyone know which fuse is for the memory buttons for the seats?
Just asking before I check every fuse in the car. Does the rear view mirror have a light on it ( that supposed to be on) perhaps they are tied together on the same fuse (cannot remember if it did or did not)... Anyways anyone know for sure which fuse is the memory seats buttons are ?
Ya just noticed today nothing is working memory setting 1 or 2 - noticed a mirror wasn't right post car was and when I pushed the button, nada. Wanted to check the fuse before the dealer looks at it. When they replaced the airbag, there was a seat sensor in the passenger sear that had moved so you could see it under the leather by the shoulder area. They moved it back however (I am guessing) since that point my seat settings stopped working.
So before I pull out each fuse one by one to check I was wondering off hand if any one knew which one it was. Like I said I could not remember if any of the lower boxes on the rear view mirror light up, if so probably related to that fuse. If not ignore the rear view mirror comment.
Ill keep looking for DPMS fuse online meanwhile
Unless changing the battery had some ill effect on the dpms system
Ya I wish it was just that and ya I tried that step many moons ago. The battery was change prior to the seat fix via dealer. However going to screw with it tomorrow and see I can see if I can solve it before the dealer appt.
They broke my steering column cover when they installed the remote starter and now the seat setting after fixing my seat.
