6MT Clutch pedal engagement point
I have a 2010 6mt, Last september I had the clutch replaced on my car due to it being completely worn out. It was covered under warranty although the service manager was very rude to me about my driving habits. Since then I feel like the clutch engagement point has been getting farther up the travel of the clutch pedal and harder to tell exactly when it will engage. I'm wary to ask the dealer as I'd prefer to never do business with them again. I could always just drive to another dealer...
I was wondering where other's clutch pedals are actually starting to engage their transmission. Mine feels like it's a little past half-way through the clutch pedal's travel. Does this sound normal? Also, does the feel of the clutch engaging seem kind of mushy to anyone else?
Is this normal or am I going to have to deal with getting it looked at?
Thanks for any input.
2G TLX-S
Is the clutch cable adjustable so you can lower the engagement height ?
Maybe the clutch cable is loose? I'm not sure what accounts for an iffy engagement point. On mine the catch point is probably on the 1/3 side of the clutch travel. But it's the same spot every time.
Dealership found nothing wrong, guess I'm just paranoid since I had to have the clutch replaced at 19k miles. Oh well, 68 bucks for peace of mind seems acceptable to me at this point.
2010 TL AWD 6MT: New King
I recall reading a magazine article, and one of their comments was that the 4G TL 6MT's clutch engagement point is "a little high up." Seems to be the "norm."
So the dealership charged you $68 to look at the clutch? Or were other services performed as well?
I remember when I first bought my 2010 sh-awd that I thought the engagement point was pretty high.
it hasn't changed, though...i'm still paranoid as you are...
My knowledge of the inner working of cars aren't especially high...would buying an upgraded after market clutch help?
I suspect that the special twin-mass flywheel that Honda chose for this car may be a contributing factor to this difficulty in detecting clutch release. Unlike a normal flywheel, this one is made up of two components connected by strong springs: when the flywheel's rotation speed drops or increases suddenly (as when engaging the clutch, upshifting or downshifting and immediately disengaging) the spring dampens the lurch by temporarily allowing one of the components of the flywheel to rotate at a different speed from the other. In practice, I believe this type of flywheel makes it less easy even for an experienced driver to detect the exact point of clutch engagement/disengagement.
By the way, this type of flywheel was introduced in Europe about 20 years ago, initially by BMW on their diesel engines, and is now quite common on European cars. Initially it was plagued by problems, with many breaking prematurely under stress, but the technology has since progressed and become quite reliable. To the best of my knowledge, this is a first for Honda or any other Japanese manufacturer.
Stefano
Ever since new I noticed that my car's clutch engagement is earlier in the travel compared to my other non-automatic cars, roughly about 1/3 of the way. Also, it is not easy to detect when the clutch is fully disengaged, which can lead to applying the gas too soon after an upshift, and therefore to premature wear of the clutch. One way around this is to release the clutch rather rapidly, faster than one would in a normal manual transmission.
Stefano
Stefano
I would also assume that if the clutch weren't fully disengaged, I would feel it when using the shifter, as well as smell the clutch burning?
Hey Guys, you can adjust the height of clutch engagement very easily, just crack the lock nut where the pin goes thru the firewall and turn the pin counter clockwise a few rotations fixed, wont hurt anything unless you go too far
Uneven clutch/brake pedal height
Just had my clutch replaced at 36k. After considerable discussions and debating with the local dealership, it was replaced under warranty, so they said, however they had me pay $500.' and maintained it was a goodwill gesture from Acura to keep me as a customer. Now like the guy who started this thread, I'm a little paranoid. It seems that the clutch pedal is now higher than the brake, and I don't remember if it was originally like that, or if it was adjusted wrong. Anybody can take a look at their pedal height and give me some feedback, I will surely appreciate it.
OP, here you go... very easy.
https://acurazine.com/forums/showt...t=clutch+throw
May be a bit too late, but seems you encountered the same issue I just had with my 6MT 4G at the dealer. How many miles did you have on the car when you needed the new clutch?
2011 SH-AWD 6MT
My concern is not the clutch engagement point, but rather the actual height of the clutch pedal in relation to the brake pedal. I have had the car since new and don't remember the clutch pedal being higher than the brake pedal. The dealership told me that they tinkered with the clutch pedal height and bled the system by hand after the new clutch was installed. If it isn't adjusted to factory specs they I'll take it back and ask them to correct it. So my question again, to anybody out there with a 6MT 4G is, are your clutch and brake pedals different heights? or are they adjusted to same height?
ETA: And I can imagine it being annoying to drive a car with it any higher. I can rest my left heal on the floor and pivot on and off the clutch pedal. Any higher and I don't think driving would be so easy.
91lgndsdn (04-11-2014)
91lgndsdn (04-12-2014)
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
kixo
09-25-2015 03:07 PM
