4G Recall..
4G Recall..
I just got a letter today from Acura stating that I need to bring my car in to my dealer to replace a couple faulty suspension bolts. Basically, the letter explains that the bolts on the left and right suspension lower arms do not have enough anti-corrosion coating on them and that over time, these bolts could corrode and loosen. I believe this applies to all 2009 TL's. Anybody else got this letter?
Yea, It's Me!
the service bulletin mentions a mark to placed near the engine compartment vin #. Since I had just purchased the car - I thought I would check for the mark - nope
The engine comp vin# is directly underneath the rear center engine comp cover
Last edited by crxb; 12-09-2008 at 08:44 PM. Reason: not a "recall' but an 'update'
Yea, It's Me!
I lucked out. My VIN is before the range listed on the Service Bulletin.
DJAROVSKY - Is there a master link to go to check for Service Bulletins and recalls? I tried to shorten the link you posted and had no luck. Thanks
The portion after the last / in the link is A for Honda, B for Acura....then the two digit year....then the TSB number.
You can also obtain a paid subscription to Honda Service Express for full access to just about everything.
https://techinfo.honda.com/rjanisis/logon.asp
DoC_TL
06-28-2007 02:26 PM
