09-14 Acura TL (UA8) / 08-12 Honda Accord (CP) /09-14 Acura TSX Part Interchangeabl
Hi guys, doing some research. I understand that the 09-15 Acura TSX (CU2) uses the frame structures of the Honda Accord (CP2), front strut hats, front chassis frame, rear chassis frame, sway bars etc etc. My question is do anyone know if the 4th Gen Acura TL uses the Accords structure?
Suspension Performance Company (SPC) lists their rear camber and toe arm kits as 09-14 Acura TL, Acura TSX, Honda Accord.
I work for a company that does chassis frame reinforcement, we are trying to figure out these questions.
I have been trying to answer that question, or a similar one, myself. Not so much because of modifications but because of cheaper parts sources. Yes, I can get cheaper parts from Honda sources than from Acura sources. So, during my research I have found out that the models to look for TL chassis, brakes, engine etc stuff is either the first generation Honda Ridgeline or older Honda Pilot years. That being said, this is not 100% accurate. So, what I do is to look for the Acura part number at the usual Acura parts web sites and then google that specific part number and see if any Honda parts web sites show up in the google results list. Hope that approach works for you too.
PS. look at Acura parts sites for rear suspension multi-link components and google these part numbers, see if any Honda parts sites show up in the google results and then trace back to the Honda model, year.
Check this out.
**09-14 TSX**
51675-TA0-A02
Base, R Front Shock Absorber Mounting
52675-TL1-E01
Base, Rear Shock Absorber Mounting
50200-TL2-E10
Sub-Frame, Front
50300-TL2-A50
Sub-Frame Assembly, Rear Suspension
**09-14 TL**
51675-TK4-A01
Base, Front Shock Absorber Mounting
52675-SEP-A02
50200-TK4-A02
Sub-Frame, Front Suspension (2WD)
50300-TK4-A01
**09-12 Accord**
51675-TA0-A02
BASE, R. FR. SHOCK ABSORBER MOUNTING
52675-TA0-A01
BASE, RR. SHOCK ABSORBER MOUNTING
50200-TA1-A02
SUB-FRAME, FR. Suspension
50300-TA0-A50
SUB-FRAME ASSY., RR. SUSPENSION
**09-14 TSX**
51675-TA0-A02
52675-TL1-E01
50200-TL2-E10
Sub-Frame, Front
50300-TL2-A50
**09-14 TL**
51675-TK4-A01
52675-SEP-A02
50200-TK4-A02
50300-TK4-A01
**09-12 Accord**
51675-TA0-A02
52675-TA0-A01
50200-TA1-A02
50300-TA0-A50
Tonyware (05-01-2017)
Update
MIDDLE ID
TA = Honda Accord
TL= Acura TSX
TK= Acura TL
Sometimes the middle ID on which vehicle it originated will change because it may fit multiple vehicles.
LAST ID
A=America
E= Europe
J=Japan
C=Canada
According to KYB Parts, the Front Strut Mount from a 2008-2012 Honda Accord EX (Only) is the same as the 2008-2014 Acura TSX Sedan/Wagon. (KYB - SM5772 / SM5773)
The top hat changes slightly for the 4th Gen TL.
Rear strut mount top hat is the same for all platforms and fits 08-12 Accord, 09-14 TSX, 09-14 TL (KYB - SM5585)
Rear strut / shocks is the same for all platforms and fits the 13-15 Accord, 09-14 TSX, 09-14 TL (KYB - 340049 EXCEL-G SHOCK)
TA = Honda Accord
TL= Acura TSX
TK= Acura TL
LAST ID
A=America
E= Europe
J=Japan
C=Canada
Check this out.
**09-14 TSX**
51675-TA0-A02
*52675-TL1-E01
50200-TL2-E10
Sub-Frame, Front
50300-TL2-A50
**09-14 TL**
51675-TK4-A01
*52675-SEP-A02
50200-TK4-A02
50300-TK4-A01
**09-12 Accord**
51675-TA0-A02
*52675-TA0-A01
50200-TA1-A02
50300-TA0-A50
**09-14 TSX**
51675-TA0-A02
*52675-TL1-E01
50200-TL2-E10
Sub-Frame, Front
50300-TL2-A50
**09-14 TL**
51675-TK4-A01
*52675-SEP-A02
50200-TK4-A02
50300-TK4-A01
**09-12 Accord**
51675-TA0-A02
*52675-TA0-A01
50200-TA1-A02
50300-TA0-A50
Rear strut mount top hat. Fits 08-12 Honda Accord, 09-14 Acura TSX, 09-14 Acura TL
KYB SM5772 - Front strut mount top hat, Fits 08-12 Honda Accord and 09-14 Acura TSX. Notice the extra stud from the TL version
KYB SM5774 - Front strut mount top hat. 09-14 Acura TL
MIDDLE ID
TA = Honda Accord
TL= Acura TSX
TK4= Acura TL 4th Gen
SEP= Acura TL 3rd Gen
LAST ID
A=America
E= Europe
J=Japan
C=Canada
TA = Honda Accord
TL= Acura TSX
LAST ID
A=America
E= Europe
J=Japan
C=Canada
Thanks for the info, thats gold !!!!
BTW, doubt the "C" is used too often, maybe just the windshield washer container and dash cluster.
Final conclusion.
I think that the 09-14 Acura TL UA8 is on its own frame and platform.
2003-2008 Acura TL (UA6/UA7) - 3Gen
2003-2007 Honda Accord 4dr (CM5) V6 - 7Gen
2008-2014 Acura TSX (CU2) - 2Gen
2008-2012 Honda Accord 4dr (CP3) - 8Gen
2009-2014 Acura TL (UA8/UA9) - 4Gen
Honda ?
2015-2017 Acura TLX ( ) - 5Gen
2013-2017 Honda Accord 4dr (CR2) V6 - 9Gen
Honda ?
