My 4G on Vossen VFS1's
I was able to get my situation figured out and didn't have to sell my wheels after all. So got them mounted today...here's a couple quick pics.
http://s16.postimg.org/jopjq0iut/photo_1.jpg http://s28.postimg.org/926aybep9/photo_2.jpg I'm very happy with them but will be getting different tires a bit wider. I'm running 255's and don't like how stretched it is. One thing though is at about 60mph I get a pretty bad vibration. It's late today so couldn't get balancing redone but hope that takes care of it tomorrow. If anyone has run into that same issue I would appreciate some input. |
Nice rims,looks really good.
I am sure you know this but will mention it in case you didn't,you did install hubcentric rings,right? It would be best if you have road force balancing done,that should take care of all your vibration issues. |
Yeah...centric rings are on. Getting balanced right now, hopefully that takes care of it. If not, is it possible that the stretch on the rear tire is what's causing it?
Originally Posted by TLCEEZ
(Post 15159826)
I doubt that the stretched tires will cause the vibrations. Hunter Road Force balancing should sort out the issues.Our car seems very susceptible to this problem with aftermarket rims. A properly trained tech on that machine will make all the difference. Make sure you use a torque wrench to manually tighten the lugs ( 94 lbs i believe) and not an air gun with a torque limiting extension. Where are you feeling the vibrations?..... in the seats and body usually indicate a problem with the rear wheels whereas feeling it in the steering, the front wheels. |
What are the specs on your rims? Looks good.
Originally Posted by KarKraze
(Post 15159844)
Originally Posted by carbonTSEX
(Post 15160295)
255/35 all around?
love the rims man! I want a set so bad lol
needs more low! |
thanks lift3d_ ...I'm only lowered on springs but happy with it. Colorado roads are shit so any lower would not be such a good idea.
(Post 15160323)
255/35 all around?
Wondering if that's part of my vibrations issue I'm having...so frustrating. |
(Post 15160912)
225/35/20 up front and 255/30/20 on rear. Wondering if that's part of my vibrations issue I'm having...so frustrating. |
Originally Posted by lift3d_
(Post 15161074)
exact same tire specs as me, hope you enjoy it!
Lifted are you running staggered on your AWD as well. Seems like a few of us are. 225/35 seems too small for the AWD since it's front wheel based. I think my 235/30 is still small though my fitment is perfect. Thinking about going 245/35 all around. I need a little more stretch for my rears at 10.5 +25 then the 255/30 I have offers but want that cushion of a 35 series. I never had vibration issues.
I like 'em-they look large, but they look good.
Where did you get your hubcentric ring from? I believe I have vibration at those speeds due to shitty hubcentric rings.
I got mine from discount tire for cheap (Local tire shop). They're just hard plastic but left no play at all.
i need those rims
Originally Posted by sKepz
(Post 15172454)
Got the vibration issues all figured out. Smooth as a whistle now :thumbsup: |
Nice what was the cause?
(Post 15175160)
Rings came with the wheels.
(Post 15175160)
Got the vibration issues all figured out. Smooth as a whistle now :thumbsup: What was it OP, don't leave us hanging! |
(Post 15175437)
Cause? Stupid a$$ tire shop I went to get my wheels mounted at first. Basically he was having such a hard time and couldn't do it. Had to go to a second place. But the damage had been done. Apparently he tried to use this gooie stuff to make the tire slide onto the wheel. Well, he put in so much on there that there was literally a big ball of goo on my rear tire :whyme: Of course...this was not seen until I bought my second set of tires and that's how I found out about this. No balancing was ever going to take care of it. It was fustrating but you live and you learn. Again, sorry for the late response. |
https://cimg0.ibsrv.net/gimg/acurazi...ac54ba1282.jpg
https://cimg1.ibsrv.net/gimg/acurazi...120a8e2685.jpg Couple pics I snapped this weekend I'm now running 245/35 up front and 255/35 on rear. I'm basically able to drive it as I did when stock :) |
Glad to hear you went wider in the front. I'm sure it improved your handling.
(Post 15183374)
i'm running a 3rd Gen TL and looking to get new rims... vossen is definitely high on my priority list they look great! Nice job btw
Just wondering, what's with the graffiti on you driveway? Your wheels look great, by the way.
Originally Posted by thebossesdaughter
(Post 15184813)
I'm interested to hear the OP's response. |
(Post 15184813)
This was years ago! To us it's like it's not even there anymore. |
(Post 15160912)
(Post 15184870)
rotfl...my brothers friends (dude working on s2k) egged his house and wrote stuff on the driveway. This one says "bola diz nuts" lol Bola is his nickname.
Originally Posted by shurik74
(Post 15186948)
Looks good amigo... Vossen's #1 on my plate. Wondering how's your AWD system is taking your front 225/35/20 & rear 255/30/20 set up?? Any error codes? Guys on AZ recommend same tires diameter all around. I'm not very pro, just wondering...
Are there any suspension or wheel differences between 2010 and 2012 models?
Originally Posted by djoulez
(Post 15192102)
I just picked up Vossen Vfs2 in Satin Bronze this week, the wheels are the same specs as yours. How much of a stretch do you have on your rear wheel? I was thinking of 275/30/20 fpr the rear. I'm not lowered yet but a set of Tein SA will be going on in the spring with the wheels.
Your car sits nice, did you roll the fenders at all? |
Originally Posted by Brock79
(Post 15212390)
275 on a 10.5 is ZERO stretch. lol.
Im running 245/35 on 11" rear. |
Originally Posted by workTL
(Post 15214204)
The wheels look great.
