KK's modded WDP Sh Awd with Rotora BBK
#842
One "no" for each wheel lol.
Thank you, the car has come a long way.
Lol, if I were to use Caliper Covers it would be custom made one's that I would fabricate myself.
I thanked each of each of you for the response but also have to admit that I was being a bit of a devil for making that post. I have purchased a BBK
and will be posting up pics a bit later. Using Caliper Covers would not be the direction that I would want my build to go.
I was looking at post 818, wow, I'm impressed with what you did to the grill. To me, you completely fixed it.
As far as your question, with regards to calipers, I think the black ones look pretty good. But, with the color of your car, I surely would not go red. But, do I plan on putting them on my car? No, I don't want them on mine.
Anyway, I'm impressed with what you've done with this car!
carbonTSEX (12-24-2016)
#843
Package sitting in the garage
Really think I need a bigger tree
For the past several weeks I have been in contact with Loren @ Rotora Brakes, most of our discussion revolved around a package for my car. He was very informative and responded quickly to any inquiries that I had. Package was shipped to me on Monday and I received it on Thursday, it would have been here on Wednesday but was held by Customs , the Govt needed their slice of the Pie (Taxes LOL ).
Really impressed with the way this kit is packaged for shipment but totally blown away by the product itself, it looks astounding!! Now, I am really looking forward to Spring. Now on to the good stuff ..........
The following 2 users liked this post by KarKraze:
carbonTSEX (12-24-2016),
SoL_TeK (12-23-2016)
KarKraze (12-23-2016)
#845
That looks like a really nice kit! Looking forward to seeing pics of them on your car.
KarKraze (12-24-2016)
#846
The Original Shawdy
Lol this guy. Good shit, glad they were able to plug you with the kit.
Are they 6 pot, 4 pot or 2 pot?
KarKraze (12-26-2016)
#847
Have to wait until Spring to install, kinda anxious .
The word "plug" in your sentence ???
#848
The Original Shawdy
brakes look fantastic.
Must. Not. Install. Yet.
#849
Hahaha, figured as much. I may have a clearance issue with the 19" rims on the Front. According to the template I have .075" or 75/1000th of an inch clearance from the top of the Caliper to the inside diameter of the rim. Lots of clearance from the Spokes, so that is causing me a bit of anxiety. At worse, 20's may be in my future.
#850
The Original Shawdy
Cant image running spacers on my IW. They're all ready wide with a crazy low offset.
#851
Yeah I measured all my wheels. Hard to say if any of them clear with the template. I did just receive my 20mm spacers though so I'll be able to install the brakes soon. Gotta make sure all my wheels fit, otherwise I'm gonna have to space them out. Rears clear no problem though.
I made a CNC metal template (not as flimsy as the paper template) using their supplied dimensions but with the correct hub bore that matches my rims perfectly. Once the measurements supplied by Rotora are accurate then it should be fine even though I am somewhat uncomfortable with the minimal clearance at the top. I will have to move the balancing weights, spoke to the Tire Shop and they assured me that would not be an issue.
carbonTSEX (01-13-2017)
#852
The Original Shawdy
It is very difficult to get an accurate fitment with the paper templates. The template supplied to me also had a different hub bore than my rims.
KarKraze (12-28-2016)
ATLS_666 (02-01-2017),
carbonTSEX (01-01-2017)
#858
I don't know if I should be jealous or just slightly aroused by the sheer sight of the Rotora's. Ok, maybe a lil bit of both. Please don't judge me' I'm only human
KarKraze (02-03-2017)
#860
The Original Shawdy
Is it spring yet!?
KarKraze (02-28-2017)
#864
Thank you, I am getting more excited as the weather warms up.
Looking forward to seeing that awesome Steering Wheel installed.
KarKraze (03-11-2017)
#866
Idk about you, but last time I checked the weather was 24 degrees and climbing so that means it's getting hot. I'm just sayin though
#867
24 degrees !! if i had that kind of weather i would be basking in the sunshine , we were under an extreme cold alert yesterday,close to - 21 C with windchill.
KarKraze (03-23-2017)
#870
Congrats on the new purchase. Those BBKs are huge! 15" and 14" rotors too?! It definitely will not clear with your existing setup without having to buy adapters. Can't wait to see how they look though!
KarKraze (04-02-2017)
#871
According to the template supplied, it should.There is a lot of space in front of the Caliper, my concern is the overall diameter, with the 15" Rotors it only gives me a .075" clearance relative to the inside diameter of the Rim.
For this reason I will do the installation at home, just in case the Rims don't clear. The 14" Rotor set up will work with the stock 18" using a 5mm spacer. I have pictures sent to me from Rotora with the 14 " set up on the stock wheels. Since I have 19's, then the additional 1" upgraded Rotors that I got should be okay.
#872
The Original Shawdy
5mm? My stock 19's don't clear the caliper without 20mm.
#876
The Original Shawdy
Must be warmer there
#877
LOL, weather still sucks but things are looking hot in the garage. .
BTW, rims fit perfect, nice clearance in front for the Caliper, the template that I made is spot on. I just have to move the balancing weights further back to clear the top of the Caliper.
Getting that done then road force balanced and I should be ready to roll. Pics to follow.
carbonTSEX (05-01-2017)
#878
Installation complete, just have to install the SPC Camber Kit , purchase 4 new Michelin Pilot Super Sport ,get an alignment and I am done for the season. The best part of working on your own car is the effort you can put in to taking care and the satisfaction of watching it unfold. Had to protect that WDP paint .
ATLS_666 (05-13-2017)
#879
The Original Shawdy
They look very nice! In for your review.
The following 2 users liked this post by jtech316:
carbonTSEX (05-02-2017),
KarKraze (05-03-2017)
