4th Gen Acura TL with Custom Grille, Custom Wheels and Performance Tires
I thought I would replace my stock Grille and 17" Wheels and Tires, for a Custom "Bentley Inspired"
Grille and 20 inch Custom Wheels and Performance Tires. I even added Chrome Door Accents.
ATLS_666 (10-10-2017)
PrinInvest119 (10-10-2017)
Good Afternoon HeartTLs,
As I mentioned earlier, I will research the bias of the wheels, as to rather they are Directional or Non-Directional, and share my findings with the community. I have, therefore, consulted with the Manufacturer of the Wheels (and tires), as well as several retailers, and they all concur that the Wheels (and Tires) are both Non-Directional.Concluding that the Wheels and Tires can both be mounted on either side of the vehicle (left or right), as long as the Tires are mounted correctly on the wheels, with the label “Outside” facing the outside of the vehicle (which they are mounted correctly). In addition, they mentioned that the tires can be Rotated from front to back, or cross-over from left to right, without compromising safety, performance or handling, or causing premature tire wear.Once again, thank you for your comments. This is why the AcuraZine Community is so useful and informative, it keeps us on the cutting edge. It's akin to the “Wisdom of the Crowd.”
PrinInvest119 (10-11-2017)
The inconvenient truth
Wow im surprised someone actually noticed that the spokes do seem to be going in different directions on each side. I can see the Bentley inspiration though, what size are the rims?
justnspace nailed it this car is large and in charge!
Nice catch on the directional wheels. Good thing is that you cant look @ the left and the right side @ the same time(unless its 2 photos side by side). And you can still rotate the tires properly. What is the chrome stuff on the china grill? Some peel & stick chrome?
Thanks for the comments Dopeboy1...the Wheels are 20" rims. Part of the Bentley Inspiration is the Custom Grille. I looked at the Grille on the Bentley Mulsanne and Continental GT, and researched the Grille Mesh for this car. I ordered it and had it custom fitted for this car to replace the Factory (stock) grille. Some of the Bentleys also come with similar wheels. Great observation.
Thank you DraginMopar...the Wheels are "Massiv 922 Swerva-Eclipse Wheels" (all Chrome), and 20" Toyo Proxes 4 Plus Ultra-High Performance Tires. What a difference it makes in the Performance and Handling of the Vehicle...
Thanks for the comments GhostTL09...yes the Wheels are working out fine...it is truly amazing how different the vehicle handles with those 20" Wheels and tires...much improved...
Great observation AtomLinks...actually the Custom Speed shop installed the chrome surround...I wanted to have the Bentley Inspired grille mesh, but still look similar to the new redesigned 2018 TLX, RLX and MDX Diamond Pendant Grille...
Beautiful car
Beautiful car...............I wanted to ask where you got your custom grille. It looks great.
Many thanks if you can give me some info on where I can locate one like that.
