4g brp 2012 tl
4g brp 2012 tl
So I've had this car since last December it has 79,000 miles on it I have been really busy with school and work so I have had no time to work on it, the only work I have done to it was replace the radiator twice and I'm going to have to do it again one of this days when it gets better outside I have been spending money on antifreeze everyday just cause I've have been so busy, my engine bay is a mess I will be cleaning it after I work on it I'm going to deep flush the radiator, I have the radiator flush cleaner from Preston and the Preston antifreeze. I will also be doing a brake flush I have the pentosin dot 4 brake fluid. I will also be changing the thermostat with its gaskets and one of the o2 sensors. I will also be adding the k&n air filters both the cabin and intake air filters. And finally I will be adding a battery holder which I am missing. After I do all this which will be all in 1 day I will be cleaning my engine bay with purple power. If there is something that I am doing wrong or you think I should do something different let me know I will be posting pictures of everything I do and all the parts. This is the car that was being put through all the unacceptable bad ownership. 😣👎🏼
New Acura Symbol
Process of removing the old Acura Symbol
Quick update- Still cold outside haven't had anytime to fix the real problems but my Acura symbol on the steering wheel was old and the silver coat it has was peeling off I cut it off and replaced it
