Sprint Booster
Sprint Booster
Ive always considered getting this for previous Hondas but never got around to it. Has anyone tried it on their tl and if so have you noticed a difference? I know the prduct and read all the positive and negative hype. Looking for a real world experience vs debate.
http://www.sprintboostersales.com/testimonials.cfm
6G TLX-S
Not applicable on Acura TL models.
6G TLX-S
The application chart in the Sprint Booster web is not showing anything for any TL models.
Would you kindly show me where ?
So if you have it or have had it , impressions?
Just like tightening the cable will not better 0-60 neither will thus. Surf around a bit and see what u think. Almost everyone who has tried it kept it. The rest are pretty much nay Sayers. A few who have purchased it eventually sold it. I think I'll try it.
2010 SH-AWD TL
2010 SH-AWD TL
Well I went and they have it. It's jrp in Mississauga Ontario Canada. They are the sole distributors. Sean was informative but ultimately they have not tested on a 2012 and talked through the potential issues. Six speed tranny change is one of the potential problems and a blown out pedal. It's because they would be using the 09-11 on it. They offered reassurance that it probably would not be a problem and if it was they would remove like it was never there and tow it to the dealer but I opted to wait to have some other owner test it out on the 2012. They said he difference was night and day. They advised what the product does is make peak up available earlier, but no up gains. So if we have 305 hp at 6400 rpm it would be for example 305 hp at 5400 rpm which means that the throttle is made open and therefore fuel at a much steeper curve then stock. They advised that everyone who tries it keeps it. I'll wait and check back with them to see if someone else tested their car before I do. Too bad, sounds pretty neat and I want to try it.
6G TLX-S
Please let us know the results.
Yea, I have only had it for a couple of days and when I have it set to Power 5 I don't have any throttle delay. I barely have to tap the pedal to get it to go. It also has an Economy setting to help with gas mileage that I'm using now to figure out if it helps or not.
2010 SH-AWD TL
2010 SH-AWD TL
That's my fault dude, I don't know how I missed that. When I search it manually, under electronics, it shows. So I assumed he still has it, but guess not.
Oh yeah the jrp guy says the sprint booster website will be updated bc it should read that the 09-11 tl is available. Its actually the same part they say as the tsx.
http://throwdownperformance.com/inde...oducts_id=3183
Dyrt can you post pictures of how/where you had the settings unit installed.
A friend has weapon r I throttle installed in his 8th gen v6 coupe accord, I'm going to drive it a bit in stock mode, high eco and most aggressive performance mode. I'll tell you guys what I think then and whether or not I think it's worth buying;friend says its the best 150 he's ever spent.
I used velcro so I can hide it when I take it to the dealer. The button next to my VSA is a modified smart plug for my old radar detector before I upgraded to a Valentine 1.
The link is the accord one. Was that just the link or the one u used? How have u found it? Noticeable? Mpg killer?
2010 SH-AWD TL
Throttle
Hi fellows, I just joined about 30 minutes ago, so I could get some insight on a sprint booster. I've had my 07 TL for 6 years and have decided to keep it a little longer; maybe give it to my son next year when he's 16. I've also decided to update it mechanically and estheticly in the interim. I see most of you drive newer TLs and Sprint Booster told me they've discontinued the application for my car because of "problems" - I think due to where it's installed under the hood. Can anyone tell me if there's a work around for my vehicle?
Appreciate it.
Appreciate it.
Reminds me of Nology of the 90's
sockr1
10-01-2015 01:31 AM
09-17-2015 09:01 PM
