Polyurethane bushings
'20 TLX SH-AWD A-Spec
Has anyone attempted to replace their front low/up control arms OEM bushings with polyurethane bushings? Or even the rear ones. Is there a kit out there somewhere from a reputable on-line retailer?
The following 3 users liked this post by justnspace:
Thanks, I'll look them up.
A friend with a brand new 4Runner replaced his with polyurethane and now has noticeable better cornering. Ride is a bit rougher but the handling compare to the OEM ones is superb. No squeaking that was expected either. I kinda wonder what effect will have to the SH-AWD on our cars. So I was doing some research to see who, if any, makes a set for the TL.
with the spherical bearings, there IS NO PLAY! and you get a more direct steering feel.
Originally Posted by sockr1
Marketing benefits
- Reduced torque steer
- Better power delivery to the ground
- Improved high-speed stability
- Durability
- Reduce wheel hop
Conclusion:
i compare this to the feeling i had when i put on the progress rear sway bar...the car feels like it's on rails in the front!! i absolutely love them and wouldn't hesitate to buy them again. at higher speeds, turning is effortless and responsive and there's no give (in a good way).
if i were to get into this car without knowing it had the bearings, i wouldn't immediately say "oh this is harsh, it must have metal spherical bearings." and that's a good thing. yes it can be "jolting" at times but overall it's a great upgrade and something that i am happy i went with. i would say 85% of the time it feels no more harsh than the oem bushings
a combination of new axles (raxles) and these PCI compliance bearings makes this car feel completely new in the front...butter smooth!
echodigital (04-07-2020)
I also noticed that. But what I am planning to do, hopefully when I have sometime, is go over the part numbers one by one for these bushings and compare 3rd gen to 4rth gen. I know the entire front upper arm is shared with all kinds of other Honda products, so perhaps the rest, at least the bushings, can be found in other models. So perhaps PCI designed bushings for other Honda/Acura arms that fit the 4th gen TLs too.
PS. BTW, anyone else, at least among the regulars here, who has noticed a deterioration of their upper control arms bushings/ball joint? It appears to me that the upper ball joint is very weak... I mean they put it on FWD Accords and then throw it on the AWD TLs too that take lots of abuse cornering because its so much fun LOL.
HeartTLs (07-07-2017)
https://www.carid.com/2010-acura-tl-...er=1&sub-model[DriveTypeName][]=FWD+%28Front+Wheel+Drive%29
That link has a couple, but i don't think its what you are looking for.
Gang Gang
Sorry for a 3 year bump
Sorry for the 3 year bump but so many people peopl'll do this when I get time and post it but did you ever get to get time to check those part numbers? The first 4g tl is now 11-12years old.
2018 TLX 2.4 (05-31-2021)
Gang Gang
HealToe has them for the 90-14 tsx. Pretty much the 09-14 tsx almost have all the same parts so if we can confirm their Compliance Bushings are the same part number then we can use the PCI ones on HealToe. They are $230 though
Midnight Mystery (08-12-2020)
