p2r manifold spacer
Old 08-27-2014, 04:54 PM
3000vr4tt's Avatar
p2r manifold spacer
anyone use this? any benefits or gains? or another worthless mod?
Old 08-27-2014, 05:08 PM
Received 16,260 Likes on 11,971 Posts
you'll see a itty bitty torque increase!
Originally Posted by thisaznboi88
Looking at 5 and up to 10 wtq on the powerband. At the cost of 1-2 HP. I'll share the dyno pix once I get the PC up and running again.
as promised. This is from an accord v6 6spd. TL will probably see similar if not more power.
ALL credit goes to Cubanob247
I also want to correct myself. You lose top end tq and a few top end HP. You gain midrange HP and gain low-mid range tq
Old 08-27-2014, 05:18 PM
the spacer pictured above is actually from the MDX. the MDX came stock with these.
I believe the p2r space is only 1 inch thick.
Old 08-27-2014, 07:54 PM
3000vr4tt's Avatar
Could there be a better difference since the p2r is smaller?
Old 08-27-2014, 08:19 PM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
What does a space do in terms of performance ?
Old 08-28-2014, 07:58 AM
you would get less gains from a smaller spacer.
Edward, you'd gain a little bit of torque in the mid-range part of the tach.
Edward'TLS (08-28-2014)
Old 08-28-2014, 08:20 AM
tcwhite's Avatar
waste of money if you ask me. I had it on my accord and could not tell a difference.
Old 08-28-2014, 07:24 PM
2G TLX-S
Edward'TLS's Avatar
How does ^ work ?
Old 08-29-2014, 06:39 AM
any air tuning is done in the intake manifold and not before it, thus why throttle spacers dont do anything.
however, the intake manifold spacer goes after the intake manifold!
throttle body --> Intake manifold --> intake manifold spacer --> injector runners --> heads.
the spacer most likely aids in air tuning by creating more volume before it enters the cylinders.
Edward'TLS (08-29-2014)
Old 08-31-2014, 10:42 PM
Reorge's Avatar
It effectively makes the individual runners longer. Do a internet search on intake runner length tuning. What year MDX had a stock spacer?
Old 08-31-2014, 10:49 PM
thisaznboi88's Avatar
all of them
Old 08-31-2014, 11:01 PM
Reorge's Avatar
The MDX spacer is a little tight for an Accord, TSX, or TL.
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-mdx-pilot-odyssey-spacer-install-749688/
Old 09-01-2014, 07:02 PM
M90booosted
03-6/6's Avatar
i installed p2r with 2 gaskets on my cls6 and it made a huge difference. more than headers did. would definitely buy again.
james357
02-13-2016 02:37 PM
CL-S progression 01
01-26-2016 04:15 PM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
Quick Reply: p2r manifold spacer
