4g TL Cams??
4g TL Cams??
Hey guys, Not having much luck finding performance cams and other head components. Maybe I’m not looking in the right place but can anyone point me in the right direction or have any ideas?
Thanks all in advance
that's because perhaps only regrinds are available...from the company bisimoto. however, the lift of the lobe is limited by the diameter of the cam bearing...cant get really aggressive.
I believe there is a company that completely makes new cams for the J-Series, but i forgot who..
and instead of searching for 4G items, search for the engine...as the J-series engine will net more results in your search for more power.
Good luck
there isnt many performance head options... build it yourself...bore, port and polish.
Basic hot rodding 101
Good luck
losiglow (06-04-2019)
I haven't heard of any plug and play cam upgrades for the 4G. There was some fiddling with the Type-S cams and Bisimoto stage cams with the 3G but it doesn't seem to be a common mod with the 4G.
bisimoto does regrinds but other than that nothing off the shelf. You can always buy a set of spare cams and send them off! They offer upgraded valve spring stuff too
Thanks for all the feedback. I did check bisimoto and also Brian crowed but found nothing for j37 options. On bisimoto, their valve springs say for j30, j32, and j35. And the same goes for their regrinds on the cams. I did try just googling j37 cams or j37 valve train, but didn’t yield anything. Just wondered if anyone had upgraded internals for this. No worries tho 👍🏻 Thanks for the help 😊
Thanks for all the feedback. I did check bisimoto and also Brian crowed but found nothing for j37 options. On bisimoto, their valve springs say for j30, j32, and j35. And the same goes for their regrinds on the cams. I did try just googling j37 cams or j37 valve train, but didn’t yield anything. Just wondered if anyone had upgraded internals for this. No worries tho Thanks for the help
Black_6spd
08-10-2006 08:26 PM
