2012 TL-ditch the speed governor
#41
As I read along this thread, I've come to wonder if the limitier is set @128 to compensate for the "extra" speed you could possibly pick up. Hills, direction of wind, etc.... So when these factors come into play, you wont exceed that safety rated tire and thus saves consumers money by not having to buy an upgraded tire that might cost twice as much as standard tires.
#44
The only reason I can figure out for limiting the car at approx. 130 is lawyers. Unless someone from Honda wants to come forward with an engineering reason.
IMHO the limit should be revealed in the technical information on the Acura website by and/or in the brochure. That would be a help to potential customers with the purchase decision.
Acc-Rite (01-26-2013)
#46
Mostly due to tires, but they are likely also put on from a legal standpoint
#47
Can someone confirm whether the manual tranny car has a 150 mph speed limiter?
According to the Acura website, all models have V rated (149 mph) tires and the base 17 inch tires have the highest load carrying ability.
So, assuming the website is correct, tire specification is not the reason for the lower speed limit on the car.
Is there a problem with the automatic transmission? I don't have much history with these cars, so - just asking.
#50
#51
Turner Falls is about the only place I can think of that has any significant grade. With the wind resistance at 130+, you would almost have to drive it off a cliff to pick up any significant speed if the car is otherwise limited to 130. However, I encourage you to try, just for fun.
#54
Hello everybody I am new to the forum, I purchased a 2012 Acura TL SHAWD last year, and the reason I am posting a message here today is because I am ashamed and seeking a shoulder to cry on.
From the previous posts I've seen here a lot of you are against the ludicrous speeds the TL is capable of reaching but are happy with the anemic limiter placed on the car. I disagree with you for the simple fact that last night, I got chased down and embarrassed at 125 mph by a Kia Optima turbo in its stock form. I was sad because I bragged about my car's performance for months and the one chance I get to prove it first hand I was let down.
Now for the rant; If Acura values its so called performance they claim is on par with BMWs and Audis who's limiters are set to 155 mph they need at least approach similar limits otherwise its all hype, if the tires are rated to 149, at least limit the car to 140. I had plans of installing a CT icebox intake and a nice cat-back exhaust, maybe even a supercharger if that ever manifests but after last night, I'd be stupid to spend the money and still be limited to the same speed as my Tundra.
I get that the car isn't a sports car but Acura didn't do their homework on their midsize competitors if their brand icon is being outperformed by an econo brand car.
I'm hurt, hold me...
#57
I would think it maybe more mechanical safety reason than anything. My 07 F150 was speed limited at 99. Was racing a buddy of mine with a Cadillac and holding him off until I hit 99 when he went by me. Started walking away crossing the bridge. Called me to let me know he hit another gear and speedometer buried itself.
Supercharded the truck and moved the limiter to 150, changed the tires of course. Another guy at the shop that tuned mine was having his done. Few weeks later while at the shop I noticed the truck in the back looking like a it was dropped off a cliff.
Tuner stated that he was racing the truck and around 155-160 the driveshaft seperated. The trucks all came with a 2 piece DS with a splicer bearing in the middle. After 130 they start to seperate and come apart. Not meant to be turned that fast. Main reason the Lightnings and Harley Davidson's came with 1 piece aluminum DS.
Sure the car probably has the motor to do it but you have to think about the drive train in the car. Never see to many all wheel drive cars that are reaching crazy speeds unless they way up in the price range and most are exotics. You want a 4K lb car with AWD to run 150-160 mph. Think about the trans speed, converter, axle speed and the rest of the rotating assembley. Converters and prop shafts are already having problems and most of them hardly ever see 100. Just my belief and I'm known to be wrong when it comes to hypotheticals
#58
I beat him off the line, pulled away from him along the on ramp, now I'm thinking he just drafted me up to the point I hit the limiter then he started getting up next to me.
After reading the post below this one, I see the other dangers involved with mechanical integrity coming into play, I have a wise friend that is completely against tuning who says if you want a fast car buy one don't rengineer a perfectly fine car in a weekend..
#60
Lol, I wouldn't take it to that extent because you have to realize there are plenty of cars out there he can buy that limiters are set much higher. My Z06 top speed is advertised as 211, the Shelby is 189 on the 2011 and 201 on the 2013.
Lots of cars can go much faster and by stating they didn't want people cutting the fool with them all cars would be governed at 80-90 mph. Not that I condone it but people are going to cut the fool. Looking under the TL at the transfercase and the way it's designed, just doesn't seem like it's set up for crazy top end speeds
#61
2G TLX-S
It is handling performance, not top-speed performance that Acura is on par with Audi, BMW, and the like.
As up to now, Acura still doesn't have 320+hp V6, high-power V8, nor high-performance division (such as Audi's S/RS and BMW's M) to compete, let alone on par, with Audi and BMW in terms of maximum vehicle top speed.
justnspace (04-23-2013)
#62
#66
#67
a GPS confirmed 152 or a speedometer 152? - if the speedometer is showing 152 its more like a true top speed of 148-149
my E60 M5 claimed it was limited to 155 but the limiter would not kick in till 174mph - ( which is more like 168-169 true speed)
BMW "required" W rated and up tires
W- 168mph speed rating
#68
I don't know that exotic materials are needed. I didn't have any problems running 165 in a 1970 Plymouth. One piece steel driveshaft, bias ply tires.
#69
You can hit 160 on H rated tires and slow back down without failure.... the speed ratings are for an extended period of time not just a top speed run and cool down. - I believe the DOT did a test on speed ratings and tire failure sometime back, it took anywhere from 25-40+ minutes above the rated speed to cause some of the tires to fail.
#70
2G TLX-S
Did the DOT test new tires or used tires ?
Tires, that have been on the road for some time, will never be as resistant to failure as brand new tires, due to the extended exposure to the elements and mechanical stresses.
The ozone and the UV are constantly degrading the rubber compound, and the imperfections on the roads are constantly stressing out the internal belts and plys. Over time, the structure of an used tire will be weakened in various degree, depending on the severity of punishments it has been through.
#71
Once again I have a hard time believing the limiter was placed on the cars for an engineering reason. I think the lawyers have been at work. They need to remove the "performance" moniker from the brochure and classify the car as a nice mid-sized sedan for old ladies.
#72
Walk the walk
#73
2G TLX-S
In this part of the country tire temps as driven by speed, but primarily road surface temperature are a big factor in tire failure.
That was when the cost of human life came in. GM did some calculations, using the cost of human life to weigh against the total cost required to redesign the C/K trucks. The lawyers estimated how many people would die or injure from the fuel tank fires, then worked out the total payout that would be required to settle the resulting lawsuits and compensations.
The result was that human life was cheaper, so GM continued to churn out the dangerous C/K trucks as is, for many more years.
Presumably, if it can happen to GM, it can also happen to other auto makers.
So, some auto makers may have predicted that not many plaintiffs are "brave" enough to drive their vehicles above 150mph; so the total human cost payout for resulting fatalities and injuries, is calculated to be much cheaper than equipping the entire model line with higher speed-rated tires.
Thus, cheaper tires are used throughout.
I guess this gamble is well worth taking, because no one in the right mind, will drive at 150mph on public roads other than on race tracks, endangering themselves and other third parties. But then when the vehicle is raced on tracks, all factory warranty/liability and even regular insurance coverage will become void.
#74
I guess it is a blessing, I hit that 128 mark a few times, I just wrap it over and then slow down before the troopers see me... I guess if it was any higher I would just wait to find how out quickly it can get there.
#75
If there were any troopers nearby you'd be covering distance too quickly to slow down before they clocked you, even if you had a lasar/radar detector. A false sense of security can only keep you warm for so long...
#76
Back in the 70/80's, GM had a design problem with it's popular C/K trucks with "sidesaddle" fuel tanks. Side impact collisions would often rupture the tanks, start a fire, and would even explode; resulting in human fatalities.
You may be confusing this story with the Pinto fuel tank problem. Those tanks, in a rear end collision, could be pushed forward into the 3rd member and rupture. The fix was a $5 plastic shield. Ford decided it was cheaper to kill people. As it turned out, not so much.
There are plenty of people in their right minds who can and do safely exceed 150 mph on public roads on a regular basis. The model line is already equiped with tires rated at 149. The additional cost for more highly rated tires would be minimal. Plenty of other auto makers have decided that 155 is a reasonable cut-off. I would be ok with that.
As for insurance/warranties, most policies/warranty coverages that I've seen void coverage if the vehicle is entered in a sanctioned event. HP driving schools, etc., where you have your car on a track in an educational setting are generally not prohibited. Check the fine print.
#77
2G TLX-S
#78
If you are talking about a contest for speed, racing another vehicle, I guess that is possible for the insurance, depending upon your carrier. If parts on your vehicle break during the warranty period, I'm not sure that your activity really matters unless the manufacturer can substantiate abuse.
#79
for the adventurous types you can try using CROME..
http://www.tunewithcrome.com/
otherwise you can inquire these guys if they have a unit suitable for your needs
http://www.phearable.net/shoppingcar...vtec-p-31.html
You are fully responsible for your own actions. Try not to blow up the engine..
Davensd
Davensd
