2012 TL-ditch the speed governor
Car is a 2012 TL FWD Auto. Based on my latest experimentation, it seems to have a 128 mph speed limiter. What is the best way to defeat the limiter? I figure a software fix, but I'm unfamiliar with this application as this is my first four wheeled Honda/Acura product (other than my mower). I appreciate the help.
6G TLX-S
It is virtually impossible to hack into the modern-day Honda/Acura PCM and modify the firmware program, without incurring astronomical cost to the handful of buyers.
Mr Marco (04-23-2013)
6G TLX-S
If the TL wasn't made to race, why would they put 305 hp in it?!?!
but seriously I'd be ok with 80 more hp and a 155 limiter...while still having it not wear a German badge...
well... you have to understand its a fwd 400 lb car.. i would understand if it had 385 hp RWD then we would say "wtf is with this limiter??"
but fact is... its a cruiser.. not a speed bullet.
Piss poor excuse. Mine is FWD (2000 TL with a stock 150 gov) and will hold its own with M3s (stock) and slightly modded STI's on lapping days. There is no reason why it couldnt have it raised.
Brochure says "sports sedan". If it says "sports", it shouldn't sign off at 130. I have had two occasions where the choice was between leaving the area and bad things. In both cases I was driving something faster than the bad guys and was able to leave. I consider it a safety issue. From my perspective, a "sports sedan" that will only run 130 is unsafe.
The following 11 users liked this post by big10purdue:
crxb (12-12-2012),
docboy (12-14-2012),
emanon256 (02-28-2013),
jnc2000 (12-11-2012),
justnspace (12-11-2012),
and 6 others liked this post.
If one does not have any expertise in that area, it can be dangerous, as you pointed out. However, there are times and places that allow that type of speed, or more, with relatively little risk. There are also times that you have to weigh that risk in comparison to other factors.
ATLS_666 (04-22-2013)
This might be a valid argument if we lived in some areas of Europe.
I'm willing to bet most of those people he's scraped off the highway also thought they had some kind of special "expertise" as well. See the issue with doing 130mph on any highway in NA is that the highways aren't designed for those speeds and people aren't accustomed to merging and dealing with traffic doing those kinds of speeds. You could be Micheal Schumacher behind the wheel and it still wouldn't matter if someone cut you off or was trying to merge in front of you at that speed.
so as to render the high speeds as safe as possible. There are thousands of miles of roads in the USA that are perfectly safe for a well maintained vehicle to travel at 130+ given the correct conditions. Don't know what roads you have been exposed to, but come to the western USA sometime and check it out. In many places the roads are good, the traffic is light to non-existant and the only thing that keeps you from seeing forever is the curvature of the earth. Happy motoring!
Exactly. One does not drive 130+ where there are limited sight lines or dangerous traffic conditions. The expertise I mentioned includes the ability to make judgements regarding road, traffic, weather and equipment conditions
try doing 130 here in socal..your not even able to reach those speeds most of the time as the road conditions will stop you from doing that.. bumps, high and low spots everywhere on the fwy and almost on every fwy..
100mph.. yes.. 130mph... no.. if the roads dont get you, the cops will.
cops are like ninjas at night, they come out of no where
Southern Cal is pretty full of people. My guess is that you have to go a ways east into the desert to find any roads that would be suitable and even then you might have to go east of Palm Springs.
I have never owned a car that had good enough headlights that I would feel comfortable at night at 130. The closest thing to that we had in our family was my dad's 1968 SS427 Impala with aircraft landing lights in the high beams. You could run 100-110 at night and still see deer and stuff in time to stop if you had the high beams on.
So, the population of people that could possibly drive "safely" in excess of 130+mph are those surrounded by desert and Europeans. Not a high enough concentration of Acura owners to warrant the change...
Like previous posters indicated... it's not just the driver. Multiple variables play a factor. US highways and streets are not the autobahn... they have numerous potholes and imperfections. Then, you have the guy next to you trying to go 130+ in his Kia as he loses control and sideswipes you.
I ALWAYS trust myself as a driver, but I don't trust the idiots around me.
Here you don't have to be in the desert to find roads that would be safe at those speeds. I'm not suggesting that everyone spend all day at 130+. What I am saying is that can be very useful to have that ability from time to time. If someone doesn't feel comfortable and/or have the experience to safely drive that fast, then I would discourage them from doing so.
Unless there are some underlying design flaws that would prevent the car from traveling faster in a safe manner, then the only cost would be a few keystrokes in the ECU programming. I believe the Civic Si is limited at 139. I find it hard to believe that it is a more capable car at speed than the TL.
I think the question should really be asked:
Why 128mph? If you're going to limit it at all, either limit it to ~85-90 (speed limit plus some) or set it at the speed at which the car would be unsafe for mechanic reasons (tires, stability, etc).
Setting it to 130 allows the driver to be horribly reckless while still limiting it, presumably for safety reasons, well below what the car is mechanically safely capable of achieving.
I'd never do 100+ in the car, but I am offended at the stupidity of the restriction they set in place. Not because of the very fact that it is implemented, but because its implementation makes ZERO sense.
Car wasn't made to go that fast. Consider it a blessing in disguise.
rossfarneth (12-23-2012)
...and quite frankly, that is a bad thing! The thing that piss me off the most is that these stupid drivers often aren't the one who get their parts picked up with a shovel, but the innocent driver/passengers in the other vehicle.
Aren't the tires considered part of the car? Someone that knows a lot more about the car than both of us thought it wouldn't be a good idea to have the car go this fast.
Chief Excellence Liason
Just out of curiosity...unless you're racing this car at the track, why would you ever need to go that fast? did you piss off a mob boss or something?
Car came stock with V rated tires which are rated for 149.
No mob bosses for now. I'll bore you with a quick version of the stories.
Family vacation to Arizona. Driving from Tucson to Lordsburg, N.M. on I-10 at the time. It was about 1:30 a.m. New Caddy with three rather unsavory looking late teens/early twenties guys pulled up beside us (had interior lights on). Paced us for about 5 miles - right next to us. I slowed down and sped up 30 - 90 and they stayed right with us. The car had no plates. Pretty much no one else on the road and I was getting more than a little uneasy.
Luckily had a Q45 at the time and it would run an honest 150. As it turns out the Caddy would not. So about 10 minutes at approx. 150 and I never saw them again.
Driving home one night about midnight on I-20 south of Dallas. Bunch of kids in an older Chevy pulled up beside me, rolled down their window and showed me a revolver.
I was driving a 455 HO Trans Am, so I left the area at 140+. They tried to keep up, but were unable to.
In both cases, I was able to avoid what I believed to be serious problems by having the ability to leave those problems behind.
As I noted earlier, a Civic Si is limited to 137 (misread it the first time). It's hard for me to believe, especially after having the car to 130, that a Civic is more capable at speed.
Once again, if you don't know that you can drive a car at high speed without endangering yourself or others, then don't do it.
FireAtWill (01-02-2013)
It still has nothing to do on whether the "car" can do it. If you have Z rated rubber on that is rated to, and no limiter the car would easily go faster and have no problem doing so and no reason it shouldnt have a higher limiter. And i bet them having it on has more to do for ins reasons and other crap like most cant and shouldnt try to, that than because you think it cant handle it.
^Perhaps the decision was based on the OEM equipment. I'd like to see what percentage of people upgrade their car with high performance equipment. I do agree that 130 mph does seem low but I'm just trying to figure out the rationale behind that decision.
Let me know when you figure out the limiter in your mower.
