Re-Activation of AcuraLink
Hi guys,
I screwed up with my 2010 TL w/tech, by pushing "yes" on deleting AcuraLink data (data rest) when I tried to delete Diagnosis Messages in AcuraLink.
Yea, went into Diagnosis Mode, by pressing 3 buttons (Map, Cancel and Menu) together.
After then, my navi won't retrieve GPS satellites at all. And after it shows OK button and push OK, it goes back to satellite seeking screen over and over.
I parked at parking lot with no trees, no building in several hundreds yards around, no luck.
In the Diagnosis Mode, I can retrieve satellites manually alright. GPS information screen shows 7-8 satellites in use after few minutes, but it is reset every time I get out of Diagnosis Mode.
Please somebody help me with this.
I can not go to dealer in Japan. There is no Acura dealer, and Honda dealers refuse to look at my TL at all.
Here is a technical bulletin on the Navi system, which, most importantly, tells you how to save the changes before exiting diagnositic screen. Hope this helps.
http://www.urvi.net/forumfiles/SB/B08-041.PDF
>mada51589
Thx for info! I checked several sources, found out that I can not re-activate AcuraLink in the countries other than North America anyway.
However, with other source and also your info, CFS settings does control satellite seeking procedure, so after I changed setting, the problem solved and Navi showed map screen no problem.
Thank you for your assistance!!!
>mada51589
echodigital (03-11-2019)
