phone not connected
phone not connected
this second time this happened to me. When trying to dial, though voice or speed dial, the screen says that the phone is not connected, but the bluetooth icon displays with the signal strength on console display and the phone says its connected too. I turned off bluetooth on the phone, and turned it back on and the console says that it is connected but not on the screen.
I have a blackberry curve, anyone else run into this. It was too cold today, to turn off the car and turn back the car to test it out again.
Not sure if I can reproduce the problem, but the only thing which comes to mind, is that I did not accept the agreement screen, and it fell to wallpaper while driving. Than I came out of the wallpaper and accepted the agreement.
I will test again later on.
Check here to see level of compatibility:
http://www.handsfreelink.com/handsfree_gateway.tml
The only fully compatible cell phone (at least for Verizon Wireless customers) is the LG VX8350.
may have not explained this right, but the curve is working fine on the HFL.
Twice the car tech screen said no phone connected, but the car display console has the bluetooth icon on and battery meter displayed. The phone itself says its connected th HFL.
Blackberry is compatible. Does everything right on the TL09, no issues.
ok
So here is what I found out so far. Get in the car, and do not accept the GPS agreement. After a certain amount of time after the wallpaper shows up, if you reach to make a call, it will give you the no phone connected on the screen, but on the dashboard and phone, it gives you the connection on.
Than you press the OK twice (1 for get out of wallpaper and 1 for agreement acceptance). Try the phone again....no go. After another time elapes than your phone is displayed on the screen.
Now the timeouts between, is what I do not know.
So that is it, you don't accept the agreement, after some time elapses the NAV says no phone avail.
Are you saying that if you accept the agreement that it will work? Or that you should NOT accept the agreement? I don't really understand your comments.
mlody
12-04-2019 02:11 PM
navtool.com
31
11-16-2015 08:30 PM
