No outgoing calls from HFL
1. I have a Samsung Note 3 (great phone, if you ask), anyways my issue is that I can not make outgoing calls while my phone is locked (screen lock). Seems like I have to unlock my phone (use password on phone) to be able to make calls from HFL.
2. Another thing I find is that my HFL won't automatically use it's speakers for outgoing calls......I have to press the headset option on my phone....otherwise my calls are first routed through my phone. This is not a big deal just wondering if others have the same issue.
My other car with aftermarket radio didn't have the above issues.
My current car I'm referring to is a 2011 Acura TL w/Tech
Any clarification will be greatly appreciated.
It is an issue with the phone. You have to update your settings for any bluetooth device to be able to use the phone when it is locked. You have to open your phone dialer app, hit the menu button on your phone to access the call settings, then find "call settings for accessory devices" or something like that. There should be an option on that page where you can change the phone settings to "allow calls from BT when ...blah blah blah". As far as the other issue goes, I think you can find a solution to that under call settings from your phone.
Chef Ray (04-06-2014)
I finally figure this out guys. For '13 TL with Nav/Tech anyway:
In phone setup (under Cellular phone menu after pressing the phone button), there is an auto transfer setting (phone to auto transfer to HFL or "Hands Free Link"). Turn this on. Any BT/Siri prompt from the phone will auto play through the speakers. Hope this helps. Also as an added bonus, when you dial from your phone - it actually "automatically transfers". Who would have thought it was this easy?
08_UA7_Gr33k
02-11-2016 02:17 PM
phillyguerrilla
09-26-2015 11:27 AM
