How to reset the diagnostic messages, 2010 TL
All,
I noticed a "low oil" warning in the diagnostics within the Info section. I'm not sure how that ever happened, but I've changed my oil and reset the service code--so the oil life goes back to 100% and the oil level is correct.
The "low oil" warning is still on. How do you reset that?
Thanks in advance.
Thanks in advance.
Did you check your oil? That warning you have is not the same as "time for maintenance".
Either you have low oil pressure or you have some other related issue that need addressing ASP.
Here it is, even though the post is for 3rd gen, the steps are the same. Note when the steps say to access the XM part, the mean to access the XM within the diagnostic and not pressing the XM button on the dash.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diagnostic-message-delete-772077/
TLguy42
09-26-2015 11:27 AM
