HFL talk button not working
Old Oct 22, 2023 | 08:34 PM
Ivantl's Avatar
Hi guys,
Just picked up a 2009 TL Base yesterday and I couldn't connect to the bluetooth. HFL button and call end button aren't responsive. When I scroll to the HandsFree Link and click more options it says no information available.
Any solutions?
Thanks in advance
Old Dec 15, 2023 | 05:12 PM
NickXavier's Avatar
6th Gear
Did you try pairing to your car first? Then it should detect your HandsFreeLink.
Old Dec 18, 2023 | 09:18 PM
Ivantl's Avatar
yes and when it’s connected, I press aux and don’t see Bluetooth audio.
Old Dec 18, 2023 | 09:55 PM
NickXavier's Avatar
6th Gear
Not related to this fix but one thing I highly recommend you is to reset settings by going to Set Up > Other > #5 Reset Factory Default and #6 Clear Personal Data since you just got this car from someone else. Also, try holding the HandsFreeLink button under the volume up/down button on the steering wheel and see if it works. Sadly, If it still doesn't work, then I can only think that the previous owners unplugged the HandsFreeLink cable on the garage opener assembly to save battery or something as these models have a history of draining batteries overnight with the HandsFreeLink, and they just wanted to be safe by unplugging it. Lastly,
should be helpful to check why it is not working for you, not complicated.
Old Dec 19, 2023 | 12:38 AM
Ivantl's Avatar
Not related to this fix but one thing I highly recommend you is to reset settings by going to Set Up > Other > #5 Reset Factory Default and #6 Clear Personal Data since you just got this car from someone else. Also, try holding the HandsFreeLink button under the volume up/down button on the steering wheel and see if it works. Sadly, If it still doesn't work, then I can only think that the previous owners unplugged the HandsFreeLink cable on the garage opener assembly to save battery or something as these models have a history of draining batteries overnight with the HandsFreeLink, and they just wanted to be safe by unplugging it. Lastly, this video should be helpful to check why it is not working for you, not complicated.
appreciate your help Nick. Most likely selling this car as I just bought another 09 TL 3.5 today and Bluetooth audio works on that one so I’m happy about that. Cheers
Old Dec 19, 2023 | 08:43 AM
vertigo2's Avatar
Press it until Bluetooth comes up, mine takes a few tries when it randomly switches to FM a few times every winter when it's really cold out.
Old Dec 19, 2023 | 12:55 PM
TLow4g's Avatar
Sauce God
who needs bluetooth when you have v6 vtec
Taylor Meyers
Jun 29, 2020 03:49 PM
noles.alum9
Mar 6, 2012 12:00 PM
schen72
Jan 11, 2008 12:03 PM
bandchief
Nov 6, 2007 07:16 PM
1995hoo
Sep 16, 2004 05:17 PM
