AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   4G TL Audio, Bluetooth, Electronics & Navigation (https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/)
-   -   Fog Lights and DRL/high beam upgrade. LEDs or HIDs? (https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/fog-lights-drl-high-beam-upgrade-leds-hids-969897/)
Andy Cheng 05-17-2018 02:55 PM
Simply put, the stock fog lights and DRLs/high beams do not look good. So I'm upgrading from the halogens. What would you guys go with? HIDs or LEDs for the fogs and DRLs? And if I went with HIDs, would something like this work?
https://www.theretrofitsource.com/h1...ect_restrict=1
TRS says these are H11B and they came up when I put in my '11 TL, despite many people saying the fogs are supposed to be H11. These are also considerably cheaper than the $150 Morimoto Elites.
Feel free to recommend where you got your bulbs from too! Thank you!
AL_BOS 05-18-2018 12:22 PM
I just recently replaced the fogs and DRL/high beams with LED, links are below. I went with less expensive options since I wasn't positive they would function properly (DRL especially) but both look and work much better than the stock halogen bulbs.
Fog lights are H11: DRL/high beam is 9005/HB3:
Teddybear 05-23-2018 08:08 AM
Fog lights are H11: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
DRL/high beam is 9005/HB3: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Does that bulb change brightness when you're on DRL vs Hi Beam on that bulb?
How's the light out put on Hi Beam?
AL_BOS 05-23-2018 03:49 PM
That was a question I had as well before I went with LEDs but I can say for sure that these are definitely dimmer as DRL and very bright as high beam, much brighter than the halogens. I really like these so far. Only issue I've had is that the light pattern is a little off but think it can be fixed by adjusting them in the housing, just haven't had a chance to play around with them yet.
Brad Stealth 11-08-2018 01:03 PM
Just wanted to know if there is something that had to be done before you install a 9005/hb3 led bulb. Ive done this plug and play many times before but for some reason (tried both bulbs) I cannot get this set to work, The leads seem to connect fine when plugging them in.
Any one ever have this problem when swapping over to led ?
agd177 12-21-2018 11:30 AM
Do Hid for the fogs and led for the drl... you cant go wrong
