Components or 2-way Front Speakers?
Wanted to poll the audience on whether most have been replacing the stock front speakers AND tweeters with aftermarket components, or just replacing the door speakers with 2-way speakers and keeping the stock tweeters. Also wondering if the stock tweeters will still function if only the door speakers are replaced. Double the tweet!
BTW, I'm looking at the Infinity Reference REF-6520 components.
What the hell...maybe I'll splurge and replace the entire front stage--doors, tweets, and center channel. Any opinions on CDT speakers? I can get a 3-way system for $600 (CDT HD-632). More than I would typically pay, but these speakers have won awards and are supposedly the shiz-nit.
Here's what you should know, alot of the OEM speakers are 2 ohm whereas most of your components are going to be 4 ohm. As you are probably aware, this means approximately half the power going to your comps/coaxs in this configuration. Do yourself a favor and pull out one of the speakers and double check before purchasing anything. Better yet, just replace the factory amp and do a proper install to achieve the sound you will ultimately want. I learned a long time ago that you only want to do an install 1 time and forget about it. Just my 2 cents tho...
Sounds like you have the premium sound system? I personally have experience replacing the base system (left the stock HU) that didn't have a center channel. In all honesty though, I am not a center channel fan as I do not watch movies while I drive nor do I want to. My opinion is that you ditch that center channel as it will screw up front stage imaging while listening to music. Also CDT is good but awards are like arseholes in that industry, everyone has got one. Many options out there and I wouldn't be hesitant to go look at all options including old school comps in the right condition. All my stuff is "new old school" and it sounds incredible but really hard to find. I didn't want to go the processor route so I had to find an amplifier to accept the stock HU balanced signal correctly. The idea is to limit the amount of devices (if possible) down the signal chain so you can listen to it in a "purer form" so to speak. Long story short, you seem like you're knowledgeable enough so choose carefully and take your time mapping out the install so you only do it once. If you are fixed on keeping the stock HU and retaining all functionality like myself, figure out what the signal is that's coming out the back of it first then go from there.
I cannot speak for that model because I have a base TSX system. What I can tell you is that it's in your best interest to research what you're dealing with before you open her up. If it's anything similar to what I have then I can certainly help you do it right the first time and you can avoid some of the problems that others have encountered. I thought that I had a center Channel but when I pop the cover off I found that there was no speaker there so just because it looks the part doesn't mean it is. There is plenty a good conversation on this forum for you to probably find the answers that you need.
I experimented with the level on the center channel, varying it between -6dB and +6dB and it sounds significantly better with a center channel. I would use the same tweeters in the center as I use in the pillars.
Also remember that your HU is equalizing and blending the piss out of those stock speakers to make them sound sonically pleasing. You will lose this preset customization as you go into a processor + aftermarket amplifier + aftermarket speakers... which is good if you can tune or know someone that can.
I think what I may do is get a single 8-channel amp, such as the JL Audio XD800, in conjunction with an Audio Control LC7i or PAC PDLC81. Channels 1 and 2 would power my front components, channels 3 and 4 would power my center channel tweeters, channels 5 and 6 would be bridged (200W RMS @4 ohms) to power my sub, and channels 7 and 8 would be available to power the rear speakers if I chose to do so. Crap, I guess I should decide on the rears now while I have the rear deck lid removed. What started out as a simple subwoofer upgrade has just turned into a complete system replacement (less the HU)!
BTW, I ended up getting the Kicker 10ZXSUM8 rather than the Audio Control or PAC unit. It has eight channels and the ability to sum up to four channels or use only as LOCs. Anxious to get everything installed.
I am looking to replace my front door speakers, as the passenger side speaker is blown. Admittedly I don't know much about car audio and am wondering if I should get a single midbass driver, or a coaxial speaker for replacement. I've seen some people say that there is a crossover in place that prevents any highs from going to the front doors, which would essentially render a tweeter in a coaxial speaker non-functional. However, some have suggested that maybe there is no crossover, in which case the tweeter in a coaxial speaker would be functional (https://acurazine.com/forums/4g-tl-a.../#post14416096). If this is indeed the case, would a coaxial speaker provide any benefit by essentially having another tweeter in addition to the factory one in the A-pillar, or would having another tweeter in the door actually be worse by throwing off the soundstage?
I would probably just get a set of individual midbass drivers over coaxials regardless, but I am having trouble finding any that are 2ohm and 6.5-inches at a reasonable price that don't also come with tweeters, as I have no plans to replace the factory tweeters in the A-pillars. Anyone have any thoughts?
Previous post was edited (got locked out while editing and changes were not saved)...
The front door speaker and pillar tweeter are in parallel, and the tweeter has a filtering capacitor on the back to filter out lower frequencies. Other than that, the signal being fed to the speakers is pretty much a full range signal, presumably with some low pass filtering provided by the head unit and/or amp (maybe 80 Hz?). That being said, you could install a mid-bass driver in the door, which is what the stock speaker is. If you can't find just a mid-bass driver, then by a component set and don't use the tweeters.
Regarding the impedance, you could install a 4 ohm speaker, but you would only get half the wattage as the stock speaker because you are doubling the resistance. You want to look for a lower wattage speaker with a higher sensitivity for the best result.
Installing coax door speakers could through off the staging, but then again it may not because as stated above you would be cutting the wattage in half, so the stock tweeters may actually be louder thereby raising the stage. In my case, it will sound good because I am also installing a new pair of tweeters in the pillars which will be on a separate amplifier channel. In other words, I will be able to adjust them independently for staging. I'm bypassing the factory amp altogether so I will have complete control. Are you adverse to installing a four channel amp and replacing all the front speakers? That would be ideal.
StevenP (05-24-2016)
I ended up just buying a component set and won't use the tweeters.
What did you end up getting? I'm curious what the power handling and sensitivity is. And I imagine you could get away with not using the cross-overs since you aren't using the tweeters. Simply connect the factory wires to the new speaker and you're done (theoretically).
Speaker +/-
When you replaced your front door speakers, how were you able to tell what wires + and -.
I just replaced my door speakers with the JBL 2-ways and its definitely more vocal but ive seemed to have lost all the bass out of all speakers which leads me to believe ive wired them wrong.
Anyone know what colors the door speakers wires are and which is positive and negative. 4G TL ELS
THanks
THanks
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
09-17-2018 07:45 PM
Pandion
05-09-2016 04:23 PM
