Big 3 Questions
Big 3 Questions
I ran the 4 AWG power wire for my amp this weekend and would like to at least upgrade the battery-to-chassis ground wire. I guess you would call this a Big 1 upgrade . Would 2 AWG suffice or should I run 0 AWG? And I don't have crimpers to crimp that large of connector, so what do you guys think of the KnuKoncepts 0 AWG screw terminals?
Yes, I do over think things. It's in my nature.
What I meant is that my amp specifies 4 AWG minimum so I'd want to increase the size of the battery-to-chassis ground wire by at least that much. Think I'll go with 2 AWG since I'm not drawing an awful lot of current anyway.
Those connectors got good reviews, although some complained that they aren't long enough and you can't get a good sized bolt on there.
I have those terminals and they work fine for me..
Hmm okay. Here is another set that appear to have more clearance...
The following 2 users liked this post by mossman77:
justnspace (05-23-2016),
thoiboi (05-23-2016)
...although one foot of 16 AWG copper stranded wire has the same resistance as 17 feet of 4 AWG wire, so I could probably just remove the factory ground and be just fine with a 12" length of 4 AWG. Makes me wonder why people do the Big 3 with 1/0 AWG. Seems way overkill.
Ac Attack
3G TL Photograph Gallery
53
10-28-2016 10:10 AM
Enrick Gatien
04-03-2016 10:26 AM
prepreludesh
03-16-2016 12:25 PM
