Aftermarket Subwoofer & Amp
i want to install an aftermarket sub & amp in my TL with a line out converter, do i need to disconnect the stock subwoofer? and how do i go about doing it?
Remove rear seat, bottom (4 bolts) then back (lift up then out, one side at time).
Remove rear deck cover (clips only).
Remove sub and use speaker wires to feed LOC. The one I bought also had a remote wire.
I used the hole for the hood release to run power and have had no issues.
t3rry_g (08-27-2013)
So you are saying that to remove the rear deck we don't have to remove the c-pillars? The manual say that these have to be removed. It would be so much easier if the c-pillars would not have to be removed.
I would also disconnect the factory sub if I was installing a aftermarket sub/box and amp. Also you could just tap into that factory sub harness for the LOC. That way, you could adjust the sub-woofer bass from the headunit still.
A big reason why I went that route.
ngravatt (08-31-2013)
InFaMouSLink
10-30-2015 09:43 AM
kb1rl
09-30-2015 10:17 AM
