Acura TL 2012 alarm/remote starter help!!!!!
hi everyone,
i am about to install my viper 5904v alarm/remote starter on my TL 2012 (push to start), but i have no clue how to wire it correctly because i don't have the wire harness diagram for the car. and i don't know that i need to buy anything else beside the 5904v set. please, anyone gives me some idea about this!
thank you!
thank you!
6G TLX-S
You can find the complete set of electrical diagrams in the Acura TL Service Manual.
Thanks to Itsinferno, who had posted a link to the electronic copy of the 09-10 TL factory service manual.
https://acurazine.com/forums/fourth-...manual-834172/
Even though the 2012 TL has slightly different electrical connections than the 09-11 TL, but it should at least give you something to work with.
The 2012 TL with push to start will require another part in addition to the Viper 5904V. You will need a data module to integrate into into the low current ignition and Can Bus system.
Viper offers the DBALL2 and as an alternative Flashlogic offers the FLCAN. Either module will need to be flashed to the proper ACURA/Honda platform so note that when purchasing the unit. Both units reduce install time significantly because the utilize the existing data system which equals less wires that will need installed. Personally I prefer the FLCAN over the DBALL2 but either is a solid option.
Fortunatly both manufactuers offer decently detailed installation instructions for your vehicle. So you will not need to reference the Service Manual.
However, you will run into an issue. Since these modules utilize the existing data system it will function just like a Factory Acura/Honda system, meaning it uses the same code a dealer installed Remote Start uses. Since you use a smart key to operate your vehicle the remote start system will shut off when you open the door to enter the vehicle. There is no way around this and you will have to start the vehicle again from inside the vehicle to drive off.
Check out Flashlogics install instructions below or download the DBALL2 from xpresskit.com which include pictures as well.
http://cdncontent2.idatalink.com/cor...N_20140813.pdf
BobbyGraham388
10-22-2015 05:05 PM
Nitin
09-30-2015 08:22 PM
