4G Base Aftermarket Radio Install
#41
im looking into a company called navtool. They have screen mirroring and Carplay and android auto for our makes and models. Once im done with my install I will let you guys know how it goes.
#43
Hey guys. I have been reading all of this thread but it seems all of you that have replaced the radio do not have the tech package. I have the tech package on my SH and have already installed all new speakers, sub, and amps. The sub sounds crazy good but the voice actually sounds worst than factory. I know its because no matter what you do, the factory radios suck. At least in my opinion compared to what I have experienced with aftermarket headunits. I am currently using the JL fix 86. It sounds ok, but I know that it could sound way better if I just had a different headunit.
Have any of you that have the tech package replaced the radio?
#44
As you have mentioned, replacing the radio in the base model seems to be a no brainer. The radio and AC are fairly separate, and the AC stuff continues to display on the top screen after replacing the factory radio with the Aftermarket Radio.
The tech version adds quite a bit if complications:
1) The AC information is displayed on the Small LCD Screen of the radio. that means if you replace the radio, you lose All visibility of the AC settings (temperature, Mode, AC ON/OFF, Fan speed, etc, etc, etc.
2) The top screen is completely controlled by the stock radio. If you replace the radio, the top screen goes completely dark. you could potentially hack it and use a Composite video to RGB adapter to connect it to your aftermarket radio as a second screen, but it would just display exactly what the screen on the aftermarket radio is displaying.
3) The tech version displays diagnostic troubleshooting information and supplemental diagnostic information for maintenance issues and trouble codes when the warning lights come on in the cluster (for example, when you get a TPMS error, it tells you which of the four wheels are not reading). All this info would be lost by replacing the radio, and you would then have to go to the dealer of a specialized Honda mechanic who can read the codes every time you get a warning light.
I'm in the same conundrum with my 2010 TL. I would LOVE a nice double din radio with CarPlay and touchscreen, but I'm not willing to lose the above functionality by making the change.
I've looked at Navtool, and while adding CarPlay would be very nice, I'm hesitant to spend that much and still not have touchscreen.while I understand it does a lot considering it is an aftermarket add-on, to my knowledge, it does not fully integrate into the car as seamless as a dedicated CarPlay receiver would.
I would love to find someone local (South Florida) who has Navtool installed so I can get some hands on testing time before committing to spend that much money.
dee_snutts (08-02-2020)
#45
#46
Is there a way to leave the factory radio but replace the screen with an aftermarket double din. I was thinking that maybe there is a way we can just set up the double din to accept the factory video output . That way you can display the factory radio information when needed on the new screen. Then, when you wanted, you would just change the input on the new radio to use apple. CarPlay.
I was looking at the wiring for the factory screen but it has a lot of wires. I read that if the canbus wires are open, it will affect other items in the system. There has got to be a way to “trick” the system into thinking the factory screen is connected. Maybe with resistors or something. Any ideas?
#47
cgardner1054 (09-15-2020)
#48
I see. So the screen you had on the top is very shallow and there is not enough room for a normal double din.
If I can figure out how to display the factory video output to aftermarket screen, I am thinking of installing a double din on top by making a custom panel.
the custom panel would eliminate the plastic clear cover in front of the stock screen and bring the new double din forward closer towards the cabin. That way you can access the touchscreen and it would give you the space needed to fit a Kenwood.
The trick is figuring out how to display the output of the factory video to the new screen. I gotta do some more research on the harness at the factory screen.
#49
help
hello,
i’ve purchased the dash kit and wired up my Sony AxAv-100 head unit to a honda harness, but as i suspected would happen, i have no audio. the head unit fires up and functions normally like it did in my accord, but the audio does not play.
my car is a 2010 TL SH-AWD Base
any info on the easiest work around would be incredibly helpful
#50
hello,
#51
Help on 2010 Tl
-thanks
#52
i tried that. the ONLY 2din radios that would fit was the ones from china... No big name brands. See photos of the system I had BEFORE I switched to navtool. Trust me....ur wasting ur times.. LOts of issues, trouble and never ending drama trying to figure out how to keep important car functions..
#54
3rd Gear
Beautiful install, I cant believe more people arent wanting to take advantage of the upper video screen. Im about to do the same on my car, any luck on finding a way to retain the factory air display on a lcd?
#55
Acura TL pioneer Radio
I haven't seen any one post about this yet, so I figured Id put up some info and a pic. Metras new kit for 09-14 came out in May- 99-7808B. Honda harness and ant adapter.
I didn't take photos on radio removal, but both side pieces snap off, and then the air vents snap straight out. (4) 8mm bolts remove the radio.
Transfer the Air controls to the new kit and mount radio(double din or single din)
If you just use the honda harness you will only get sound out of the front speakers. I ran RCA's for an amp at a later date. I used couplers off those and another set of cheap RCA's to cut off and tap into the factory amp inputs(passenger side rear behind trunk panel)
There is not a lot of room behind the radio, but it wasn't too terrible to get everything to fit.
Sound with stock stuff is ok, not terrible but better than with stock radio.
#57
i had a 2005 TL and now i have a 2010. what i did on my 05 was take apart the factory radio and i put the circuit board out of it and plugged it in. i tucked it in my dash so the factory navigation would still work and i wouldnt have a blank screen on my dash. but in my 2010 with the dash kit it seems to eliminate the controls for the navigation. so,, im a bit hesitant on changing out my head unit. but i would love to put my pioneer double din in
sKepz
48
06-19-2018 05:11 PM
KayBee
02-14-2016 12:39 PM
3pt2TypeS
14
06-08-2014 01:51 AM
Diesel_Blue_TL
03-15-2002 12:54 AM
