'09 TL Navigation System reboot when select destination
the Nav started to act up since the beginning of the month. every time you choose a destination from the OK button, the system reboot. please see the attached URL for the video. anybody run into this problem?
Thanks so much
Thanks so much
Yeah, I had my navigation randomly rebooting like that too. I took it to the dealership and they just replaced the unit under warranty. But, he said he wanted to verify the battery was okay and that the XM signal wasn't causing it first (which apparently can be culprits as well).
Thanks. i stopped XM awhile back in 2010, and have a new battery in 2012. it has been fine until this month. is there a way to reset the NAV system? the reset to factory default from the setup menu didn't work. thanks again
Got it fixed with the 2014 Red DVD Application Update 2.8 DISC 1. I borrowed DISC 1 from a friend and used it to do the update. didn't use DISC 2 to update the map of course because of the VIN + Password.
rockyboy
08-04-2024 10:35 AM
Tim Giron
03-18-2016 09:50 PM
Gianni Formica
09-07-2015 08:28 PM
